MPU 6050 X Y Z degree outputs
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
I looked at the topic and the blog.
I did not know how to get a degree output.
Can you help me get XYZ degree outputs?
Topic: http://www.flowcode.co.uk/mmforums/viewt ... 050#p73643
Blog: http://www.flowcode.co.uk/blog/quadrocop ... -and-gyro/
Re: MPU 6050 X Y Z degree outputs
You cannot do a Z axis with a MPU6050 because there is no magnetometer available. Most magnetometers I have used have been extremely disappointing but to be fair I don't often get a lot of time to play with them and it could simply be a calibration issue.
As for X and Y rotations these should be covered in the blog via the Roll and Pitch angles?
STibor
Post by STibor »
Does the example program return pitch and roll angle?
The linked Arduino program would be perfect for migrating in Flowcode.
Project: https://www.instructables.com/id/How-to ... 050GY-521/
Ino download: https://cdn.instructables.com/ORIG/FDJ/ ... JTLNU0.ino
Thanks for the help!
STibor
Post by STibor »
Hello!
I set the two example programs into 1 program.
I made a mistake because the filter sim pitch and the filter's sim roll variable value are incremented / changed per measurement.
Why is the value of "filter pitch" increasing?
mpu6050_serial_output.txt
(388.31 KiB) Downloaded 299 times
MPU-6050_SimFilter_Ardu2.fcfx
(21.44 KiB) Downloaded 302 times
