making hex file un readable
billduck
- Has thanked: 23 times
- Been thanked: 16 times
Is there a way within Flowcode ver 7 to prevent the downloaded hex file not to be readible from an Arduino UNO?
Re: making hex file un readable
Yes there should be lock bits you can set via AVR studio etc. You will need a ICSP such as the AVRtiny or AVRISPmkII to be able to access the device memory without using the Arduino Bootloader.
billduck
The following link shows how to use Atmel Studio to set lock bits. It points out that the only way to undo the lock bit is to erase the device. The bootloader is erased, so that has to be reloaded.
https://www.youtube.com/watch?v=cr0VDOlGVlU
