Using these settings for SPI:
No data output at all on any pins channel1 (channel 2 not tested).
Software mode:
No data on either enable or MISO.
Data present on clock and MOSI
Using external osc @ 20MHZ.
1ms pulse within a loop is correct.
I can PM project if required.
SPI Hardware & Software 18F47K40
Re: SPI Hardware & Software 18F47K40
Hopefully now found, fixed and rolled out for the whole family
Also available via the update system now.
Thanks, Ben,
That's Great!
Will give you an update on the results after testing tomorrow.
That's Great!
All working with channel 1 and software.
Not tested with CH2, assuming to work as well.
Thank you
Thank you
