Preferences button not vissible
Any general or miscellaneous queries that do not fit into the other forum catagories
Walbeek
Flowcode v5 User
Been thanked: 3 times
Post by Walbeek »
Hi there,
When I add a switch or LED component to Flowcode, I can change the number of switches / LED's with the preferences menu on top of the switch / LED window. Sometimes I only need one switch / LED, so the number of .. is changed to 1. After clicking the OK butoon, the button for the preferences and connections menu is gone, because the window is to narrow. I can't change the connections anymore.
Is there any other way to change these?
Please let me know.
Best regards, Rinie
Greetings, Rinie
Flowcode V7 user
Re: Preferences button not vissible
Hello Rinie
The Switch component seems to be big enough not to experience this problem (at least on my machine) however the problem does exist with the LED component. Luckily if you click the far left hand side of the LED component at the top it will bring up the hidden menu. Good spot though, I'll try to add a fix for this to the update list for the next release.
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
Flowcode v4 will not have this problem because it will not have components in windows as in v3.
