Display TM1637!
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Display TM1637!
Post by jgu1 »
Hi All!
I have just received some of these display TM1637:
https://www.ebay.com/itm/Red-Blue-Green ... 2749.l2649
I have made a small testprogram i FC8 with the TM1637 component.
In addition to a clock, it can be used for many other purposes.
All functions working perfect with FC8. :D
Br Jorgen-
TM1637.fcfx
(13.08 KiB) Downloaded 1052 times
Proflolo
Has thanked: 1 time
Been thanked: 1 time
Re: Display TM1637!
Post by Proflolo »
I am French teacher.
Where did you find the TM1637 7SEGMENT(QUAD) ?
Thanks.
Re: Display TM1637!
Hi Proflolo,
(16.91 KiB) Downloaded 8698 times
Just use Search
Re: Display TM1637!
Also available from Displays -> Display: Segment, it's right near the bottom of the displays list.
Re: Display TM1637!
Benj wrote:Also available from Displays -> Display: Segment, it's right near the bottom of the displays list.
Yes, if you use the search then where the location of component is will be shown.
See the green outline in the image on my previous post.
Proflolo
Has thanked: 1 time
Re: Display TM1637!
Post by Proflolo »
Bonjour,
Je suis désolé de vous répondre par la négative.
Mais je n'ai pas le TM1637 dans ma bibliothèque.
Ci-joint, ma copie d'écran.
(199.87 KiB) Downloaded 8623 times
Re: Display TM1637!
You must have the latest version installed!
Vous devez avoir la dernière version installée
(16.46 KiB) Downloaded 8616 times
(123.99 KiB) Downloaded 8616 times
Proflolo
Has thanked: 1 time
Re: Display TM1637!
Post by Proflolo »
Merci beaucoup..
Effectivement, c'était tout siple.
Je vous remercie beaucoup.
Bonne soirée
bercioiu
Has thanked: 90 times
Been thanked: 34 times
Re: Display TM1637!
Post by bercioiu »
Good evening!
I use this topic to avoid opening another.
I have an application where I have to use 3 quad 7 segment displays.I have found that I can use the quad 7 segment display led by the TM1637 driver in Flowcode. I already have 3 displays available. Now I have some questions about component 7Segment (Quad TM1637), which I hope to find answers here:
1. How do I send Flowcode information to the 3 displays if they are cascaded?
2. How can I use the decimal point (dp)?
Thanks in advance!
Puiu
L.E.
3. How do I "print" custom characters?
Re: Display TM1637!
You can simply just connect different I/O to different display pins. This allows you to connect and control multiple units.
Does your unit have a DP outputs? Can you show us which specific unit you are using.
Currently we allow the characters 0-9 and A-F. I can expose a lower level macro to allow you to control the individual segments if this would help.
bercioiu
Re: Display TM1637!
Post by bercioiu »
Yes, it has decimal points and I have to use it ...
If it connects cascaded, I only have two lines of command CLK and DIO.
I want, for example, to write "u" or "U", how can I do that?
Thank you!
WhatsApp Image 2019-02-04 at 3.33.02 PM.jpeg (103.59 KiB) Viewed 34283 times
WhatsApp Image 2019-02-04 at 3.33.01 PM.jpeg (88.23 KiB) Viewed 34283 times
Re: Display TM1637!
Aha we based the component off the Grove module which doesn't have the decimal points or the cascade functionality.
Let me investigate for you.
bercioiu
Re: Display TM1637!
Post by bercioiu »
I am already on the second project with TM1637 and I'm struck by the same problem: I can not use the decimal point. This time I really need to, because I'm doing a DRO.
Can anyone change TM1637 component for FC8?
Thank you!
bercioiu
Re: Display TM1637!
Post by bercioiu »
Please help me at least by directly accessing the segments to print custom characters, with the decimal point I can do by myself with the addition of a transistor.
Thank you!
Re: Display TM1637!
Thanks for letting me know. I have added a new ShowSegments macro to allow you to manually control the individual display segments.
bercioiu
Re: Display TM1637!
Post by bercioiu »
First of all, thank you for helping me again, sir!
I did a test, but I do not see how the macro works ...
Can you look at the file?
Once again, thank you!
test_TM1637.fcfx
(9.51 KiB) Downloaded 688 times
Re: Display TM1637!
Sorry I forgot to check the simulation was running too. I've now fixed this and it should now be working nicely.
Please note I have changed the parameters for the new SetSegments macro slightly so you will have to edit any icons that reference the function.
bercioiu
Re: Display TM1637!
Post by bercioiu »
Now, everything seems to be all right and everything goes well.
Thank you again!
