PIC16F15355 Uart and ADC problem
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
patrick schoon
Has thanked: 7 times
Been thanked: 13 times
Post by patrick schoon »
My project with PIC16F15355 has a problem with the Hardware uart.
I get an undefined identifier error at compiling the project.
Title:
Description:
Device: PIC.16F.16F15355
Generated by: Flowcode v7.3.0.5
Date: Thursday, December 20, 2018 19:34:08
Users: 1
Registered to: ps
Licence key: X7--
http://www.flowcode.co.uk
Launching the compiler...
Microchip MPLAB XC8 C Compiler (Free Mode) V1.41
Build date: Jan 24 2017
Part Support Version: 1.41
366: RX1PPS = 15;
^ (192) undefined identifier "RX1PPS"
(908) exit status = 1
FINISHED
Uart in software setting works.
Second i tried to use the ADC.
Also here several undefined identifiers.
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_ADC.c: FC_CAL_ADC_Enable()
4756: ADREF = 0x00;
^ (192) undefined identifier "ADREF"
4771: ADPCH = 0x01;
^ (192) undefined identifier "ADPCH"
5008: ADCLK = Conv_Speed & 0x3F;
^ (192) undefined identifier "ADCLK"
5019: ADCON0bits.ADGO = 1;
^ (255) not a member of the struct/union ""
^ (182) illegal conversion between types
int -> volatile union S53
C:\Program Files (x86)\Flowcode 7\CAL\PIC\PIC_CAL_ADC.c: FC_CAL_ADC_Sample()
5027: while (ADCON0bits.ADGO);
^ (199) logical type required
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe reported error code 1
FINISHED
Also PWM only uses Timer2 and only PWM 1 and 2 do compile but no working results
PWM 3-6 do give compiling mesages..
Testfile.fcfx
(12.76 KiB) Downloaded 512 times
Please check, and thanks.
Re: PIC16F15355 Uart and ADC problem
Hi patrick,
If you update to the latest version (7.3.0.7),
then that will eliminate UART bug and just leave ADC bug.
I can fix it for you, but it means replacing two files.
Would you like me to produce updated files,
or would you rather wait for MM staff to produce official update?
patrick schoon
Thanks for the quick support.
I Can't find the latest 7.3.0.7 online!
But you may send me the two patch files.
I know how it works.
Thanks.
You're welcome,
Have you tried here?
Hi Patrick,
Attached are the two updated files:
16F15355.fcdx goes in C:\Program Files (x86)\Flowcode 7\FCD (if 64bit windows) or C:\Program Files\Flowcode 7\FCD (if 32bit windows)
PIC_CAL_ADC.c goes in C:\Program Files (x86)\Flowcode 7\CAL\PIC (if 64bit windows) or C:\Program Files\Flowcode 7\CAL\PIC (if 32bit windows)
16F15355.fcdx
(27.91 KiB) Downloaded 487 times
PIC_CAL_ADC.c
(132.17 KiB) Downloaded 544 times
patrick schoon
All thumbs up. :D
The ADC and both hardware uarts are working now.
I still get compiling errors when using timer 1 and 2, timer 0 is working well.
Proberly this is also the issue why the pwm is not working. Pwm is only using timer2.
Pwm ch 1 and 2 can be compiled but no working results, 3-6 also give compiling errors.
Many thanks for now.
Patrick
Hi Patrick,
patrick schoon wrote:The ADC and both hardware uarts are working now.
I'm glad it's working, thanks for letting me know.
patrick schoon wrote:I still get compiling errors when using timer 1 and 2
I did not know there is an issue with timers and PWM.
I can't make any promises,
but I will see if I can get those working as well?
Hi Patrick,
Can you see if the attached solves your issues?
16F15355.fcdx
(31.75 KiB) Downloaded 471 times
patrick schoon
Many thanks in such short notice. :D
Both timers do compile and work on their own.
When used both (TMR1 and 2) they disturb each other, I get interupted pulses.. Proberly swatped some code...
Timer0 is ok.
Simple example in the attachment.
Test.fcfx
(22.84 KiB) Downloaded 564 times
Great help, thanks.
Patrick
You're welcome.
Does the PWM work now?
patrick schoon
I did a quick test but no working results.
To be sure i deleted all timer2 components and reselected a new pwm component.
But no working output. Compiling does work..
Patrick
Try adding a c code block at the start with
T2CLKCON = 1;
medelec35 wrote:Try adding a c code block at the start with
T2CLKCON = 1;
You will need the above code for timer 2 to work, including PWM
patrick schoon
Sorry,
No results.
Attached my test file for check.
Test.fcfx
(24.23 KiB) Downloaded 558 times
Patrick
