AVR lock bits
iain wilkie
Has thanked: 13 times
Been thanked: 9 times
AVR lock bits
Post by iain wilkie »
Is there a way of setting the lock bits in an AVR from within Flowcode ?
Easy to do using Avrdudess but would be handy if it could be done from within Flowcode.
Using an ATTiny261.
Cheers
Re: AVR lock bits
This certainly used to work from inside Flowcode with the AVRISPmkII but I must admit I currently also use AvrDudess whenever the need arises, it's fairly rare I use AVRs and when I do more often than not I use an Arduino with fuses already pre-programmed.
What programmer hardware are you using and I'll investigate for you.
iain wilkie
Re: AVR lock bits
Hi Benj,
Currently using the AVRispmk2 programmer, but have ordered the tinyusb one from Matrix but it’s not here yet.
Once it’s here that (hopefully shortly) that will be my go to programmer.
Iain
