Watch Dog Timer
keejay
Flowcode v5 User
Been thanked: 15 times
Watch Dog Timer
Post by keejay »
I'm getting a compile error when I try to clear the watch dog timer with C-Code block. It worked great in version 6. I'm using:
clear_wdt();
and get the following error when I try an compile the program in FC8:
C:\ELECTR~1\PROJECTS\G_Lert\SOFTWA~1\V2>C:\PROGRA~2\Flowcode\Common\COMPIL~1\pic\batch\..\bin\xc8.exe --chip=18F46K22 "401.c" --MSGDISABLE=359,1273,1388 --FLOAT=32 --DOUBLE=32
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
401.c: FCM_SMS_RESPONSE()
7067: clear_wdt();
^ (361) function declared implicit int (warning)
using updated 32-bit floating-point libraries; improved accuracy might increase code size
0: (499) undefined symbol:
_clear_wdt(401.obj)
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
FINISHED
keejay
Flowcode v5 User
Re: Watch Dog Timer
Post by keejay »
If I disable all the clear_wdt(); then the programs compiles successfully.
keejay
Flowcode v5 User
Re: Watch Dog Timer
Post by keejay »
It appears as though
ClrWdt();
compiles without errors
Re: Watch Dog Timer
We support the function like this in v6, v7 and v8 to remove the need for using compiler specific syntax.
MX_CLEAR_WATCHDOG;
This should work on various targets which support watchdog timers, e.g. PIC, AVR etc.
