I know this will be simple for many but is there a basic example for using interrupts from PortB of a PIC?
Basically, a number of buttons on PortB, two of which need to break a function (reset and A.N.other)
Enable an interrupt
Run code as normal
If a key is pressed break from the run-mode and do 'something else'.
Sounds simple and probably is but I can't get my head around it in FlowCode.
FlowCode interrupts for RB0
Re: FlowCode interrupts for RB0
An RB0 interrupt in Flowcode occurs when you switch the logic level from pin RB0 from low to high or visa versa depending on your interrupt enable properties.
To switch the RB0 input from high to low you are going to need an external pull up or pull down resistor.
Eg here is a typical circuit using a single push to make switch and a 4.7K resistor.
5V----Switch----RB0----4.7K Resistor-----GND
When the interrupt is triggered the macro you selected via Flowcode will be run once.
Hope this helps.
Hope this helps.
Ben,
I'm okay with that level. I guess the question was for a simple sample of using a port interrupt within Flowcode.
Doh!
sorted now.
Doh!
I am trying to do an emergency stop using the RB0 interrupt. The problem is that when the interrupt is triggered,
the macro chosen is only done once,
What can I do to loop until the button is released? I did a loop in the macro but still it run only once :S
Thanks for your help
, and I need it to continue to run until the emergency stop is released.When the interrupt is triggered the macro you selected via Flowcode
will be run once
tomcat14
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
Hi kirmstom14,
This is how I would do it :
This only works well when there is no delay in the "else" part of the program.
Nicolas
//main program
char stop = 0; // variable for stopbutton used as a "flag"
while(1) // main loop
if (stop == 1)
// do stuff
// when stuff done
stop = 0;
else
// do some other stuff
// interrupt
stop = 1; // stop button pressed
Nicolas
