Expansion Modules dspMIAC - Error
gavo4
Been thanked: 8 times
Post by gavo4 »
Hi Leigh and Benj,
I have a strange issue with the advanced expansion module, I keep getting an error:
C:\Program Files (x86)\Flowcode\Common\Compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
When I try the example file Leigh sent before it works perfectly, the minute I take out all the references to the expansion module (initialize and Digital output macro) and re-compile it, it compiles 100%, do you know why i would get this error and when I use the example code for the expansion module it works 100%?.
gavo4
Re: Expansion Modules dspMIAC - Error
Post by gavo4 »
Running the code below on its own run perfectly with no errors
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Could you post the project that gives the error?
Re-creating the above images I do not get any errors
Leigh
LeighM
Post by LeighM »
Hi Gavin,
When you use Expansion modules, the project target needs to be "MIAC (dsPIC) System"
Leigh
gavo4
Post by gavo4 »
Oops thanks Leigh!,
Do you know why the program would reset (every 5-10 minutes) if left idle plugged in to my USB?
LeighM
Post by LeighM »
Does this only happen when USB connected?
gavo4
Post by gavo4 »
Hi Leigh,
Both with USB connected and unconnected, I have run the simulations and can't find a reset?
Gavin
LeighM
Post by LeighM »
What power supply are you using for the MIAC and Expansion modules?
What voltage and current capability?
gavo4
Post by gavo4 »
its a Meanwell - NES-35-12 it a 12V 3.0A Supply, supplying both the MIAC and Miac Expansion
LeighM
Post by LeighM »
Hi Gavin,
OK, the PSU is good :D
I've not had chance to go through all your program, but I do see some instances of reentrancy,
that is, routines/macros calling themselves, this will cause problems, that can result in a reset.
For an example, RTC_SET calls HOUR_1 which calls RTC_SET
Leigh
gavo4
Post by gavo4 »
Thanks Leigh,
I just needed the program to go "back" in-case the user made an error.
LeighM
Post by LeighM »
One way to do that is to use connection points to the macro end
gavo4
Post by gavo4 »
Thanks Leigh, how do you do that across different Macro's?
LeighM
Post by LeighM »
You cannot.
But you can use it to exit from a macro when the user cancels.
gavo4
Post by gavo4 »
My Apologies Leigh, do you have an example?
gavo4
Post by gavo4 »
Somehow I think the issue is with all the tag routines
LeighM
Post by LeighM »
Yes, I think you are correct
There is a lot of one calling another, this will cause stack problems.
Try and get the execution back to Main, have a read up on state machines.
That is, use a state variable to decide what gets called from Main.
gavo4
Post by gavo4 »
Thanks Leigh!,
Will check it out...;-)
gavo4
Post by gavo4 »
