I am having an issue working on this MEGA2560 board trying to read Modbus Slave registers.
The strange deal about it, is that everything looks fine; the slave addressing, baud rate, COM Port, addressing of registers.
I've tested it with another MEGA2560 board and same result. Could it potentially be something in the Modbus module?
What could be causing this issue and how can I resolve it? Thanks
I've attached a test program that I'm using.
Problem Reading Modbus Registers
- AtMega2560 Modbus Test.fcfx
- (87.37 KiB) Downloaded 217 times
I'm just trying to keep learning & growing in a infinite loop... unless I wanna break. Cheers
Steven
Steven
Re: Problem Reading Modbus Registers
Hi Steven,
What sorts of problems have you been seeing so I can try and narrow things down? I've had a look through your program and not spotted anything obvious so far.
Hi Benj,
The program compiles fine and it uploads to the board fine, then I open up the Modbus client-server and set up the registers from 40001-so on.
When I run it to read the Modbus slave registers... no values appear, no reply is returned, nothing is coming back through the RX...
[Edit]Is it possible that I could get the raw code of the modbus slave module? I'm running out of ideas and thinking it might be something in there
Steven
Steven
Hi Steven,
What version of Flowcode are you using?
Currently using Flowcode V8...Benj wrote: What version of Flowcode are you using?
Steven
Steven
Hi Steven,
I've sent you a PM.
I've sent you a PM.
