Component entries that have been exposed to Top level and are in white can be moved to a different position.
I'm trying to move new field up that is not in white and it's not letting me.
Is there a way of moving it please?
Moving shaded exposed entry
Re: Moving shaded exposed entry
One way is to switch the channel to software mode so that the property becomes editable. Another way is to edit the project file XML in a text editor though this obviously isn't ideal.
I want to implement a change where top level properties are always movable and deletable but currently this hasn't made it in.
Thanks Ben.
I hope it can make it for the next update, as it makes component creation easier!
I second that.Benj wrote:I want to implement a change where top level properties are always movable
