PIC16F1939
Did everything right!
But all shifted !!!
ILI9341 16bit It's not working
- DISPLAY.fcfx
- Disp
- (9.7 KiB) Downloaded 264 times
- Prog
- FC8_ILI9341_16b.jpg (27.92 KiB) Viewed 4551 times
- File
- Disp.jpg (111.31 KiB) Viewed 4551 times
Re: ILI9341 16bit It's not working
I have exposed the component macros LCD_Write_Reg and LCD_Write_Data8. These should allow you to play around with the various register on the display to try and remove the offset. I've pushed this new version to the update system now.
I'm guessing it's something like the vertical scrolling or vertical scroll start address that's at fault on your display though there are lots of registers so I could easily be wrong. Look at the ILI9341 datasheet and find the registers I'm talking about and maybe others.
For the vertical scrolling command you would send the command like this.
LCD_Write_Reg (0x33) //Command
LCD_Write_Data8 (0xXX) //Parameter 1
LCD_Write_Data8 (0xXX) //Parameter 2
LCD_Write_Data8 (0xXX) //Parameter 3
LCD_Write_Data8 (0xXX) //Parameter 4
LCD_Write_Data8 (0xXX) //Parameter 5
LCD_Write_Data8 (0xXX) //Parameter 6
Keep playing until you get something different and that's when you may be on the right track.
Hope this helps.
Hope this helps.
Hi Osta
What registers did you try changing?
If you count how many pixels your off by then I can add a new offset property for you to override the problem via the component.
Hi Benj!!!
I have to go away on business !
When I get back, I'll check!
Osta.
Osta.
Hi Benj!!!
I'll check and answer this weekend.
With respect Osta.
With respect Osta.
Continued here.
viewtopic.php?f=78&t=21182
