Bluetooth Modul RN4870 RN4871
Has thanked: 182 times
Been thanked: 179 times
What about a very small BT Modul add to FC8?
Bluetooth Modul (RN4870) RN4871
There is
- P-Mod Modul Digilent
- clickerboard
- Lot of infos
- It is in the Altium Designer avaible
Features
• Fully Qualified Bluetooth® Low Energy Module
• Certified to FCC, IC, CE, KCC, NCC and SRRC
• On-Board Bluetooth 4.2 Low Energy Stack
• ASCII Command Interface API over UART
• Compact Form Factor – The RN4870/71 family
- RN4870: 12 mm x 22 mm
- RN4871: 9 mm x 11.5 mm
• UART Transparent Service for Serial Data Applications
• Remote Configuration Over The Air
(122.65 KiB) Downloaded 2056 times
https://store.digilentinc.com/pmod-ble- ... interface/
(253.01 KiB) Downloaded 2056 times
clickerboard
(316.67 KiB) Downloaded 2056 times
https://www.mikroe.com/rn4871-click
some more infos
https://www.mouser.ch/new/microchip/mic ... 70-rn4871/
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Bluetooth Modul RN4870 RN4871
Post by LeighM »
Did you know about this one, based on RN4677?
https://www.flowcode.co.uk/webshop/e-blo ... board.html
Hi Leigh
Thank you for the info. The Modul RN4677 I know and it's in my selection too.
The RN4677 modul support the SPP profile.
Hhhmmm it's double size of the RN4871....
But I did not see the module E-blocks2 BL0170. I could build the whole module on my board. I mean I could put the 16Pol plug on my board, then I can also connect other E-blocks2. Is there any info which plug or even an example of the Altium designer?
(319.29 KiB) Downloaded 2047 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team.
I have to support Stephan here it would be great if you can help with the board connector for the Eblocks 2 it will help us
to place these connectors on our boards and plug the eblocks in directly :D
Type,partnomber and supplies :D
The EB2 connector you are looking for is the Har-flex 16-way connector from Harting. You can get them via RS.
https://uk.rs-online.com/web/p/pcb-sockets/8439052/
The pin out for the EB2 boards can be found in the EB2 datasheet on page 5.
https://www.flowcode.co.uk/old_site/resources/get ... hp?id=1075
QMESAR
Post by QMESAR »
Thanks a million Ben :D
Thank you for the Infos. It's easy this way to add some E-block's to an own board.
