E-blocks 2 BL0011
VladimirRepin
Has thanked: 1 time
Been thanked: 3 times
E-blocks 2 BL0011
Post by VladimirRepin »
There is a problem with BL0011.
After connecting via USB, Windows sees it, but mLoader (v4) does not see, and when the program is recorded on the chip, a notification appears that the device is not connected.
This result is in Flowcode 8.0 and 8.2.
With BL0080 and PIC16F18877 there is no such problem.
Any idea what the problem might be?
VladimirRepin
Has thanked: 1 time
Re: E-blocks 2 BL0011
Okay, I solved this problem.
You need to install the necessary drivers for the board.
When you updating drivers, you must manually select them in the Flowcode v8 / Drivers folder.
This solved the problem.
P.S. Do not forget to update Flowcode to the latest version.
