Hello all
I have come it pickle with my Master pitch count. Running into to much code.
I cleaned up old code that was disabled and deleted 2 old macro.
Went from ( -5 ) to (-2), Getting close
I had a old thought if I had several Delays with 10ms I could call say Macro10 that would have the 10ms delay.
Will calling a Macro for Delays save on word count?
Here is my Message
ROM available:16384 words, used:17043 words (102.0%), free:-659 words (-2.0%)
Is there a way in flowcode 6 to see the word count before I send to chip?
John
Call a macro for time delays
Re: Call a macro for time delays
Hi John,
Maybe try making a new constant, assigning the value 10 and then referencing the constant. If this fails then it's worth a go.
The compile to hex option allows you to compile without programming.
- JLeith
- Has thanked: 146 times
- Been thanked: 26 times
Hello Benj
Not 100% sure how to use the Constant
I can create something that resembles a 2 second timer. But it doesn't look right.
And how to I call it in a 2 second timer ?
In the images the "Macro2s" was a call for 2 second timer.
I have attached my Flowcode 6 design maybe you can spot a cleanup or how to work with Constants. Google doesn't give me much knowledge.
John
John
- Pitcher Master June 19.fcfx
- (337.62 KiB) Downloaded 256 times
Hi John,
If you have code like this.
do this
delay_ms(10)
do that
delay_ms(10)
do the other
delay_ms(10)
then you can create a constant with the value 10 e.g. myconst and then the code would look like this.
do this
delay_ms(myconst)
do that
delay_ms(myconst)
do the other
delay_ms(myconst)
I'll have a scan through your program and see if I can spot anything for you.
Some of the variables have initialiser values and then are initialised again in the START macro. Pitch, AlarmH and StopHM to name a few.
do this
delay_ms(10)
do that
delay_ms(10)
do the other
delay_ms(10)
do this
delay_ms(myconst)
do that
delay_ms(myconst)
do the other
delay_ms(myconst)
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Hi John,
You also have some repeating code that could be replaced with macros,
in particular, in the Keypad macro you have a lot of strings to print on the display that are copies,
maybe you could create PrintHomeMenu and PrintAwayMenu macros.
In fact there is only one string difference between these two, so maybe have a PrintMenu macro that has a menu selection parameter,
then within the macro if selection is 0 print home, or if 1 print away.
I also noticed that in the menu print you have a string print followed by a screen clear.
