Can not read the ADC at Attiny84
Xbeejunior
Has thanked: 9 times
Been thanked: 3 times
Post by Xbeejunior »
Hi Team,
I'm trying to read a voltage on the ADC port of Attiny84, I've already tried all possible settings, but to no avail, I get only the "0" on LCD!
It works in the simulation......I think I get the ADC simply not switched !?
With an Attiny85 has it ever worked, at a certain voltage, I turned on a port, only to read on an LCD has too few ports.
I'm grateful for every tip!
Greetings
Ralf
Re: Can not read the ADC at Attiny84
Hello Ralf,
Just looking into this for you and the ADC code looks ok.
One thing I spotted is that there is a digital input disable register mentioned in the datasheet. It doesn't say it is required to be set for ADC conversion but it's work a go.
DIDR0 = 0x3F;  //Disable Digital Inputs
DIDR0 = 0x00;  //Enable Digital Inputs
Let us know if this helps and if so I will add the code to the ADC component.
Xbeejunior
Hello Benj,
thanks for your support :)
As I have inserted it in the attached test program, it does not work either! I only get a short "3" displayed when I declare GetByte in the component, I do that with GetInt I get the short "15" displayed!
I try to evaluate the voltage on an ADXL335 module, the measured voltage of an axis in the basic position is at 1.8V ......
I'm looking forward to more ideas and I'm curious what stupid mistakes I currently make :D
Thanks again
ADC and LCD Test Attiny84.fcfx
(19.69 KiB) Downloaded 353 times
