I could not use FC8 opening the old flowcode fcf file.
Any way to convert the fcf file to fcfx?
Thank you
YCC
FC8 could not open fcf file
Re: FC8 could not open fcf file
If you would like to post or PM file,
then we can convert it for you.
That's correct.
The option to import fcf files was removed in Flowcode V8.
bertrandsbk
hello , i have same trouble with file and impossible to open one old file could you help me
Hi bertrandsbk,
Welcome to the forums.
If you like to post fcf file,
I can convert it for you.
If you would like the fcf file to remain private, then you can pm or a member of matrix staff.
bertrandsbk
thanks lot Medelec35
this is the file.
this is the file.
- grifpeintureV3.fcf
- (34.98 KiB) Downloaded 199 times
Your welcome.
Attached is file converted to V8
It maybe worth replacing the V5 components with V8 equivalent.
- grifpeintureV3.fcfx
- (33.71 KiB) Downloaded 208 times
bertrandsbk
