Model 3D et AllCode
Model 3D et AllCode
Bonjour,
J'aimerai rajouter un model 3D au allcode et qu'il bouge en même temps que lui lors des mouvements.
J'ai regroupé l'ensemble mais le Allcode bouge seul. Comment faire bouger l'ensemble?
Merci d'avance
Bruno
Merci d'avance
Bruno
- Allcode et objet.fcfx
- (13.29 KiB) Downloaded 736 times
Re: Model 3D et AllCode
Bonjour Bruno,
C’est quelque chose pour lequel nous pouvons ajouter un soutien sans trop de problèmes.
Quelle version de Flowcode utilisez-vous et je vais étudier un moyen intéressant de permettre cela.
Hello Bruno,
This is something we can add support for without too much hassle.
Which version of Flowcode are you using and I will investigate a nice way of allowing for this.
Hello Bruno,
J'ai ajouté une nouvelle propriété au composant dans FCv8 et cela peut être dirigé vers votre groupe contenant le FA et les nouveaux bits montés.
Espérons que cela devrait faire tout ce dont vous avez besoin.
I've added a new property to the component in FCv8 and this can be pointed to your group containing the FA and the new mounted bits.
Hopefully this should do everything you need.
Hi Bruno,
I'm struggling to get the mod into the v7 component. I'll keep trying but so far it's throwing problems at me.
I ended up having to build the component with v8 so maybe make a backup of the file first just in case I have broken something fundemental.
The file lives here.
C:\Program Files (x86)\Flowcode 7\components\
Let me know how you get on.
Aha sorry I've spotted the problem now. This file should work correctly.
Hello Benj and sorry again!
The model has good addon mech but the objects do not follow the Allcode...
Bruno
Bruno
- (4.62 KiB) Downloaded 2961 times
- GIF.gif (59.35 KiB) Viewed 34336 times
Thanks for letting me know. It's working for me in v8 so could be down to how you have grouped things. I just selected the FA and everything else I wanted to move with it and grouped them together.
Can you attach your program so I can see your grouping.
here it is.
- Flowcode1_testmodel3d avec allcode.fcfx
- (14.64 KiB) Downloaded 708 times
Aha, thanks it's the logo commands that are not working with the group.
For now here's a prog that works
I'll get this fixed but it will probably be tomorrow if that's ok, I'm out of the office today.
Yes, I had not tested the right macros!
It works now with all non-logo commands and the result is great. My students can now simulate their robot.
BUT compliation no longer works to generate code C!
BrunoErreurs au cours de la génération du code source C:
Flowcode1_testmodel3d avec allcode.c : 10312 : error : Composant inconnu ou absent: PWM_AudioOut1::Enable
Flowcode1_testmodel3d avec allcode.c : 10314 : error : Composant inconnu ou absent: PWM_AudioOut1::SetDuty10Bit
Flowcode1_testmodel3d avec allcode.c : 10342 : error : Composant inconnu ou absent: PWM_AudioOut1::Disable
Flowcode1_testmodel3d avec allcode.c : 10953 : error : Composant inconnu ou absent: LCD_Backlight::Enable
Flowcode1_testmodel3d avec allcode.c : 10957 : error : Composant inconnu ou absent: LCD_Backlight::Disable
Flowcode1_testmodel3d avec allcode.c : 10962 : error : Composant inconnu ou absent: LCD_Backlight::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11194 : error : Composant inconnu ou absent: PWM_LeftMotorFW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11196 : error : Composant inconnu ou absent: PWM_LeftMotorFW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11204 : error : Composant inconnu ou absent: PWM_LeftMotorBW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11206 : error : Composant inconnu ou absent: PWM_LeftMotorBW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11233 : error : Composant inconnu ou absent: PWM_RightMotorFW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11235 : error : Composant inconnu ou absent: PWM_RightMotorFW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11243 : error : Composant inconnu ou absent: PWM_RightMotorBW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11245 : error : Composant inconnu ou absent: PWM_RightMotorBW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11445 : error : Composant inconnu ou absent: PWM_LeftMotorFW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11447 : error : Composant inconnu ou absent: PWM_LeftMotorFW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11457 : error : Composant inconnu ou absent: PWM_LeftMotorBW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11459 : error : Composant inconnu ou absent: PWM_LeftMotorBW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11491 : error : Composant inconnu ou absent: PWM_RightMotorFW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11493 : error : Composant inconnu ou absent: PWM_RightMotorFW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11503 : error : Composant inconnu ou absent: PWM_RightMotorBW1::Enable
Flowcode1_testmodel3d avec allcode.c : 11505 : error : Composant inconnu ou absent: PWM_RightMotorBW1::SetDuty8Bit
Flowcode1_testmodel3d avec allcode.c : 11830 : error : Composant inconnu ou absent: PWM_LeftMotorBW1::ChangePeriod
- GIF2.gif (303.71 KiB) Viewed 34302 times
Many thanks for letting me know. I have now added the functionality to the logo movement functions so hopefully these should work well now too.
I have looked into the compiling issue and beleive this has also been solved for you now.
