Flowcode V8.2.1.13 Build Aug 6 2019
give some strange error
With the "old version2 there are no errors
Flowcode V8.2.0.12 Build 3 May 2019
Flowcode V8.2.13 error
- Has thanked: 182 times
- Been thanked: 179 times
- Fc8_efg100_emg_ekg_prototype_v15_J100Mega1-cal_spi.fcfx
- (477.67 KiB) Downloaded 218 times
Re: Flowcode V8.2.13 error
Hi Stefan,
I think we're going to need more information on the error. Is it when compiling? Can you provide a screen shot or text of the error.
It compiled ok for me but there was a lot of warnings. Ideally if you can use hardware channels for your UART components.
I installed the new version on a second computer.
If I compile to hex I have the errors. But with the display is nothing wrong.
Yes there are a lot of warnings, but it's working on the old version on my "working" computer.
Some more Problem with V8.2.13 it's crashing few times on the new computer and I have to restart the computer.
Is it correct to download the FlowcodeV8_Installer and let it run on a new computer or do I need the patch and hotfix additional?
Hello Stefan,
Have you applied all the various component and definition updates using the Help -> Check for updates menu?
I can't do much without seeing the project file and the errors you are getting on the compiler output window.
I think you just need to run the latest installer and then also apply the hotfix if you want the very latest version.
I tried the Hotfix on the bad computer, but some problem.
So I did the same on a notebook and there every thing is working fine and not crashing.
On the bad computer I removed my own FC Program and copied the my own FC Program again.
and every thing is working fine now.
This message is still if I try the hotfix to install, but FC8 is working fine. I think it's ok.
