Same pin problem. Im' going to stop here. Something is wrong. I'll let you dig into it..
Chad
Pic32mz Uart broken.
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Pic32mz Uart broken.
Hi Chad
I expect that you will have many problems as the definitions file for this device has an issue it is not possible to allocate pins to the peripherals
Ben and team will look at this , this is my humble opinion by trying to use PWM and UART on the same chip as a test today
Regards QMESAR
Regards QMESAR
- QMESAR
Hi Ben.
as you can see here the UART pins are unconnected and the option to remap shows zero options
Regards QMESAR
Regards QMESAR
Great spot, thanks for letting us know. Should be fixed now via the update system.
