AP102 LEDs
mnf
Has thanked: 70 times
Been thanked: 440 times
AP102 LEDs
Post by mnf »
Just noticed a small bug in the Arduino (I've tested) implementation of AP102C component.
A simple single strand of LEDs connected to SPI (hardware) works AOK - if you remember to set B2 to output.
- But I noticed that one LED was not lit.
Rather than counting to 60 (ran out of fingers) - I reset the strip length to 10 - and only 9 LEDs are lit at the start of the strand.
Note that all the LEDs are functional - (setting the strand length to 61 lights all the LEDs although there are only 60)
There isn't a 'hidden' LED at the start of the strand.
The C code looks OK - for SetAllLEDColour and Refresh. (while FCL_INDEX < 10 - gives 0..9)
The Adafruit strandtest works correctly....
mnf
Re: AP102 LEDs
Post by mnf »
The cause of this is the lack of an end frame in Refresh()..
From the data sheet:
(125.43 KiB) Downloaded 906 times
So adding my own refresh macro which adds an end frame:
- and the correct number of LEDs now illuminated..
chad
Has thanked: 27 times
Been thanked: 33 times
Re: AP102 LEDs
Post by chad »
Thanks for looking at this. At some point I am going to be using a bunch of apa102s.
Chad
mnf
Re: AP102 LEDs
Post by mnf »
Not quite a complete fix - needs the bit-bang alternative too! Hopefully easy for Ben & co to incorporate.
I've been trying (and failing) to get them working with an ATTiny85...
Re: AP102 LEDs
Brilliant, Thanks for letting us know and well done for finding the cause of the problem.
I've added the End Frame to the refresh function now and pushed the fix to the update system.
Let me know how you get on.
