Hi Monie
A few years ago I used one of these in FC4, so had to write the code myself.
Is this any help.
http://www.flowcode.co.uk/mmforums/viewt ... it=+acs712
ACS712 component doing wrong
Monie Jacobsen
- Has thanked: 17 times
- Been thanked: 46 times
Re: ACS712 component doing wrong
Hi John
Yes I have seen your examble and in the moment I use it and it work fine
But now when Jordy have made a component for this ACSxx I any case it would be easyer to use for me. I would be Happy if anybody could fix it or make a new component. I am sadly not able to do it.
Best Regard
Monie
Monie
Hi Monie,
It seems Jordy's component is working fine, the problem your having is due to lack of ROM on the 877A device.
So on AVR
ROM = 7604 bytes - close to the 8192 limit of the PIC device your using.
RAM = 100 bytes
What about using the PIC16F1937 or PIC16F1939 instead of the PIC16F877A? The 1937 has slightly more ROM available and the 1939 has more than double.
Compiling for PIC using Flowcode 6. (Interestingly the program does seem to compile ok for Flowcode 7 using PIC.)It seemed to work on Arduino. But on a pic16fxx I still get the compilemessage “ ROM available:8192 words, used:8248 words (100.6%), free:-56 words (0.-6%)” ??
So I wonder, how much rom does it use when I use a Arduino and am I also almost on the limit usage and why does it use so much space in a Pic??
Compiling for an Arduino Uno.RAM available:368 bytes, used:252 bytes (68.5%), free:116 bytes (31.5%),
Heap size:116 bytes, Heap max single alloc:95 bytes
ROM available:8192 words, used:8692 words (106.1%), free:-500 words (-6.-1%)
Too much code to fit in ROM, overfilled by:500 locations.
The GCC compiler output is a little different but you can say that the ROM usage is the Text section and the RAM usage is the Data and BSS sectionstext data bss dec hex filename
7604 28 72 7704 1e18 C:\Users\BenR\Desktop\PIC16F876AampASC7.elf
So on AVR
RAM = 100 bytes
Monie Jacobsen
Hi Benj
Thanks for your reply Ben. Yes right I can use a bigger size , but if there is a bug in the component macro, I do not believe it is the right solution and just increase the size.
But Ben will try to look at the attached example. If you try to simulate it looks like that the 2 analog inputs have influence on each other, and it act the same way in real world.
Attached error eksemple:
Best Regard
Monie
Monie
Hello Monie,
Aha it seems the current ACS712 component is not switching analogue channel to reflect your property change.
To check this click View -> Component Debugger.
Click to check the "Expose full component tree" item in the Component Debugger window.
On the properties window select the drop down menu at the top of the window.
Select the Slider Plastic component just underneath the ACS7xx component.
The Channel property is still set to 0, changing this property should correctly allow you to configure the Analogue pin connection of the component.
You can double check that this has worked by looking at the properties of the ADC base or CAL ADC components underneath the Slider Plastic component.
Alternatively you can check by looking at the generated C code.
There should be two sections like the code below, one for each ADC based component you have on the panel.
#define ADC_2_MX_ADC_ACTIME 40
#define MX_ADC_REF
#define ADC_2_MX_ADC_VREFVOL 500
#define MX_ADC_CHANNEL_0
#define MX_ADC_TYPE_2
#define ADC_2_MX_ADC_VREFOP 0
#define ADC_2_MX_ADC_CONVSP 3
#define MX_ADC_BITS_10
#define ADC_2_MX_ADC_CHANNEL 0Code: Select all
#define ADC_1_MX_ADC_ACTIME 40
#define MX_ADC_REF
#define ADC_1_MX_ADC_VREFVOL 500
#define MX_ADC_CHANNEL_3
#define ADC_1_MX_ADC_VREFOP 0
#define ADC_1_MX_ADC_CONVSP 3
#define ADC_1_MX_ADC_CHANNEL 3Regards Ben Rowland - MatrixTSL
Monie Jacobsen
Hello Benj
Thank´s.
I try your suggestion, but it doest work I still get the same error -2 Used to much rom.
Is it difficult to create a new component?
Sadly I am not able to do it.
GO'Weekend
Thank´s.
GO'Weekend
Best Regard
Monie
Monie
Hi Monie,
It's a bit of work to create a component and at the moment we have a very busy schedule. It's not difficult as such but there is a lot to get right.
I can probably eventually build a new component to get rid of the ADC channel bug we have discovered. However this will probably not decrease the ROM usage so you will still get the "Out of ROM" type compiler error messages.
For now it should be possible to work around the ADC channel bug using the fix I posted and using a Microcontroller with more available ROM.
hi sir john
i've seen your project very helpful, I am working on a project that has to work for AC Current reading. Can someone please help me modify a code for AC Current Reading using this ACS 712 current sensor. Thank you everyone.
Steve001
- Has thanked: 460 times
- Been thanked: 523 times
Hi Tadz
When using AC these type of sensors will output a AC Waveform
one option is by using a "precision rectifier" and a small capacitor to convert this to DC then the standard ADC component can read the value
https://en.wikipedia.org/wiki/Precision_rectifier
Hope this helps
Hope this helps
