How to use max31855 component?
Tried int, float output on ili9341 all zero.
MAX31855
Re: MAX31855
I'm using the component here and it's working well for me though there was a bug that got fixed earlier this week so make sur eyou are using the latest version of the component.
You also need to do a Sample before you can read the temperatures.
If you're still having problems then please can you attach your program and I'll have a look for you.
Re: MAX31855
But how to make a sample?
I turn on the sample variable bute
It turns out an error.
Please see the program, what needs to be changed - add.
Thanks.
Thanks.
- MAX31855.fcfx
- (10.42 KiB) Downloaded 171 times
Re: MAX31855
You need to call the MAX31855 Sample function in your loop before you call the ReadThermocouple function.
Hopefully that's all that is required.
Re: MAX31855
Erroneous result
- MAX31855.fcfx
- (10.62 KiB) Downloaded 177 times
- (107.75 KiB) Downloaded 703 times
Re: MAX31855
Right I've now solved a problem where the simulation was not working and returning values. This is now available in the update system.
Please can you try this and hopefully it will work better for you, or at least give you an idea as to what is wrong.
