RTC for MIAC(Part two)
acestu
Has thanked: 783 times
Been thanked: 223 times
Re: RTC for MIAC(Part two)
Post by acestu »
Ok Enamul,
I have connected the 0v on the MIAC to the neg rail on my slave breadboard but still nothing ?
Does the cable need to be shielded twisted pair or does it not matter for 12 inches or so ?
thanks
Acestu
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Not an issue for short distance and your house environment. I think issue is related to code.
Enamul
University of Nottingham
enamul4mm@gmail.com
Enamul
Post by Enamul »
Hi Stuart,
Can you please try this code and let me know?
RTC_MIAC.fcf
Please use what Stuart posted..this misses start of LCD
(22.98 KiB) Downloaded 396 times
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
I have programmed the new code but I get a blank screen, I then reprogrammed with keyboard test prog and was fine, then reprogrammed with new code again and I still get blank screen even connected to the can bus etc.
thanks
Acestu
acestu
Post by acestu »
Hi Enamul,
I have looked at the code and the "Display Start" was missing so I put it in and reprogrammed and Voila !
All working now with Date & Time
Acestu
RTC_MIAC_Final.fcf
(23.12 KiB) Downloaded 446 times
acestu
Post by acestu »
Hi Enamul,
All I need to know now really is can this RTC slave unit be incorporated into the bootloader of the MIAC ie part of the system so that it always keeps time, or does your code that is in the MIAC now have to be incorporated into whatever program you write for the MIAC ?
Hope that makes sense !
Thank you for all your help Enamul as always
Acestu
P.S. It is interesting that when the "Display Start" was left out of the code, Flowcode still simulated the display.....
Enamul
Post by Enamul »
Hi Stuart,
It great to know that you have sorted it. I don't have MIAC in hand but I keep that in first priority. That's why I can't test the code before posting..I noticed the mistake of missing start LCD macro in earlier post but I have been working from uni and home machine and I thought it was corrected one. Anyway, you caught the issue; that's even better.
First of all RTC slave unit needs physical hardware like slave module with RTC module and I don't think it's possible. But you can keep time easily with the existing set-up if you have coin cell battery connected to RTC module..if slave or MIAC power goes off still RTC module can keep time.
Yes, I think if you want to have the feature of RTC you have to add the code we have used for MIAC in all program. But the good thing is that CAN bus is so fast you can do whatever you want in between RTC data read.
Yes, that's something really need to be improved in FC simulation. If simulation would show what hardware shows; things will be much easier..
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Thanks Enamul,
Now that everything is done and working I will put all the ingredients into a folder and upload it soon for anyone that is interested in this post.....
Thanks again
Acestu :D
Enamul
Post by Enamul »
Hi stuart,
One more thing you can add with the code is...adding a feature of setting time from MIAC. That should work as MIAC has a Keypad interfaced with it already and so you don't need to suffer for any connection :)
Enamul
enamul4mm@gmail.com
acestu
Post by acestu »
Hi Enamul,
Yes that would be great to add that time set feature to the program that you put into the MIAC, that is going to be my next project, so don't run off lol...
Anyway I am including an archive file with all the info for this thread now, so anybody interested can have a go ....
Acestu :wink:
MIAC_RTC.rar
(169.92 KiB) Downloaded 430 times
P.S. you can download Winrar to expand the archive file.
DylanBalloo
Flowcode V4 User
Post by DylanBalloo »
Hello Enamul,
Regarding the Keypad test program I have a few queries?
Firstly, in the main program, regarding the second loop that you place, why did you put TEST LOOP AT THE END?AND WHY KEYVAL IS 255 NOT 0
Secondly in the keyDecode macro, can we use the variable keyval instead of the keyDecode.keyval? and in the loop that you add at the bottom why did you put <>255?
Thank you.....
Enamul
Post by Enamul »
Keypad is read first then it is checked..if you check at start you have to put read outside the loop and inside loop. but we can avoid one more macro by checking at the end..default return is 255 if nothing pressed. so we will be in the loop until no button pressed.
keyval is local variable in the keyDecode macro..so have to use either keyDecode.keyval or .keyval format...but if you declare global variable keyval; you will be able to use simply keyval in all macro.
Last loop with condition keyDecode.keyval<>255 is waiting till you release the button..as if you released the button cause the keyDecode.keyval = 255 so the loop will wait till it become 255 i.e. button release which will in other way provides switch debounce or one one key return for one press.
Enamul
enamul4mm@gmail.com
