SSD1305 Component Macro problem?
Re: SSD1305 Component Macro problem?
Hello Ben,
Unfortunately, the situation has not changed. I see the same as the previous photo.
On the left side of the image pixels are lit scattered in 4 column.
In the four column the "Clear Display" function is not working.
And it would be nice if the 0,0 point is to appear in the upper left corner.
Thanks,
Lagoda
Thanks,
Lagoda
Hi Lagoda,
Have you changed the value of the H Offset property? I thought a value of 4 would fix the issue, the default is 0. Have you tried any other values?
I checked, surely I changed to the new file.
And I set the following:
X=4 Y=0 "Thanks for helping"
X=4 Y=32"Volume=1000"
Now it looks like
Now it looks like
- SSD1305test_4.jpg (96.95 KiB) Viewed 11911 times
Hi Lagonda,
Please can you attach your current Flowcode program just so I can be sure we are on the same page.
I attached it.
- 1305display_test011.fcfx
- (8.74 KiB) Downloaded 338 times
Hi Lagoda,
Thanks for the file. Please can you try this and let me know how you get on. I'm hoping that coordinate 0,0 should be 0,0 on the display now using the H Offset property with the value 4.
Brilliant, looks like we're finally there.
I've rolled out the changes to the none buffered SSD1305 component now too if anyone else needs this.
Let me know if anything else crops up.
Hello Ben,
Thank you very much for your help.
I am very pleased because I can handling the display.
I hope this will be the last question from this component.
How can I to rotate the display content?
If I using the "Display Orientation" function with parameter "2" I get the next screen:
Do you have any idea?
Best Regards,
Lagoda
Best Regards,
Lagoda
- 1305display_test013.fcfx
- (8.96 KiB) Downloaded 352 times
- SSD1305test_6.jpg (89.48 KiB) Viewed 11896 times
The lit pixels directly underneath the text is interesting. All the display orientation macro should do is fiddle the coordinates.
0, 0 becomes 127,63
1, 1 becomes 126, 62
It looks like this display your using is really messed up in terms of it's addressing. I'll take another look at the code but I can't really see a nice way of solving this at the moment.
Maybe you could do a bit more testing. e.g. light up specific pixels and see if you can map which pixels are working and which aren't.
0, 0 becomes 127,63
I tried a few settings.
Is this help for you?
- 1305display_test015.fcfx
- (11.03 KiB) Downloaded 350 times
- (167 KiB) Downloaded 1504 times
- (251.35 KiB) Downloaded 1504 times
Right please can you try this out and hopefully the problem will now be resolved.
Printing "OOOOOO" at 94, 0 is ok.
Printing "123123123" at 0, 59 is not ok. The coordinates should be 0, 54 to correctly fit the vertical 8 bits onto the screen at pixels 54-63.
0, 55 will also probably work ok as the text is generally only 7 pixels high.
Hello Ben,
It's magic!
Each pixel lit in their own position and what I programmed The Component Macro does it.
Super.
I think this bug is cured by you.
Best Regards,
Lagoda
It's magic!
Super.
Best Regards,
Lagoda
- SSD1305test_9.jpg (95.89 KiB) Viewed 11874 times
Phew, that is good news
Glad I could be of help. Turns out a lot of the display components had the same problem so I have been through and fixed it in all of them now.
Thanks for your patience and help to get this up and running.
