Internal Real Time Clock RTCC PIC8 & PIC16
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Re: Internal Real Time Clock RTCC PIC8 & PIC16
Post by AbhijitR »
Hello! Ben
Following your post I tried to use the Auto Version ID function, it is really a fantastic utility.
But now I am stuck up with another issue, I was not able to convert the string data to integer, I mean I could write the instruction but I lost the data after conversion. I took "Date" from auto version as string i.e. 27-02-2019 then converted the same to integer which eventually ended up in only 27. I tried to read the post but not getting the correct link, may I request you to shed some light.
I check the conversion/result on the LCD screen and on computer simulation.
Thank you, hear you soon.
Abhi
Hello Abhi,
Thanks very much :D I created it mainly for the Formula AllCode robot, the build stats are automatically shown on the LCD when you compile firmware to the FA robot along with things like the battery charge level.
I've made you a quick example here. It collects the date string and then uses string manipulation to collect the day, month and year as integer variables which are then printed to an LCD. The time string would work in the same way.
StringManipulation.fcfx
(10.24 KiB) Downloaded 349 times
AbhijitR
Post by AbhijitR »
Oh! Ben
You really make things so simple but to be really honest with you, I was thinking in good direction but was not doing it right, lack of experience. :(
Humbly thank you again, have a pleasant evening.
Abhi
