Internal Real Time Clock RTCC PIC8 & PIC16
I've managed to spend some time investigating the RTCC peripheral on board the PIC 8-bit and 16-bit devices and think I now have it cracked.
Below are a set of files designed to allow you to test out the new functionality.
Simply extract the files into your "Flowcode 7" folder and restart Flowcode to apply the changes.
Flowcode 7 RTCC.zip
(1.25 MiB) Downloaded 817 times
The updated Real Time Clock (RTC) component is then available from the storage component category.
If you have a go then let us know how you get on.
If all is well then I will add these files to the main updates archive.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Internal Real Time Clock RTCC PIC8 & PIC16
Post by QMESAR »
Thank you very much Ben highly apprecaited :D
Currently no alarm support, let me know if this is a requirement for anyone and what you would need the alarm to be able to do.
viki2000
Has thanked: 30 times
Been thanked: 77 times
Post by viki2000 »
The Alarms would be useful.
I intend to use DSPIC33FJ64GP802 or DSPIC33FJ128GP802. They have inside RTCC and Alarms.
https://eu.mouser.com/search/ProductDet ... 64GP802ISP
https://eu.mouser.com/search/ProductDet ... 28GP802ISP
Microchip info about RTCC for dsPIC33F/PIC24H Family:
http://ww1.microchip.com/downloads/en/D ... 70301C.pdf
http://ww1.microchip.com/downloads/en/D ... 05193a.pdf
The Alarm macro when is called, it should provide a test bit true if the alarms take/took place and false before that time – that for simple test in a loop. And additional to that it would be useful to provide an interrupt, which would not require any loop for test. In the interrupt macro the user cam then write his code. That is described in the above pdf files. The alarm is also mentioned to be “ONE-SHORT ALARM” and with “CHIME DISABLE/ENABLE”:
Is it any “RTCC CALIBRATION” implemented in the RTCC component?
viki2000
Post by viki2000 »
Does anyone tried the RTC component and it works?
If yes, then with what MCU? Do you have a test program?
I have tried RTC with dsPIC33FJ128GP802 and for me it does not work. I opened up a question here:
viewtopic.php?f=7&t=19621
viki2000
Post by viki2000 »
Would be possible to share the source code of the RTC, so we can start debug it, because it seems it has errors, I think in initialization, in some cases as dsPIC33FJ128GP802 for example?
If not, can you debug it or try to find out what other settings, C code must be added to the existing component to make it run properly with dsPIC33FJ128GP802 for example?
Hi Viki,
I've sent you a PM with the component source so you can have a look. Could it be a chip configuration issue?
Has thanked: 182 times
Been thanked: 179 times
I have a Pic32MZ2048 with a internal RTCC. But if I use component RTC from FC7.3, I can only choose DS1307 or DS3231.
How can I choose the internal RTCC from the PIC?
Hi Stefan,
What's the rest of the PIC32 part number so I can look at the specific definition file?
Pic32MZ2048...... Matches with 24 devices.
:D
I used the PIC32MZ2048EFG100
I have added the RTCC definition to the FCDX file and hopefully that is all that's required.
Simply copy the attached file to your "Flowcode 7/FCD/PIC32" folder and restart Flowcode and the Internal option should then be available for you.
32MZ2048EFG100.fcdx
(74.04 KiB) Downloaded 330 times
Let us know how you get on.
Now I can choose the internal RTCC.
But I can only choose the external osci on the componet properties.
Even if the external clock for the RTCC is selected I think the internal osci is connected.
good that I need the internal osci anyway.
It's working nice.
(40.87 KiB) Downloaded 5389 times
(24.92 KiB) Downloaded 5389 times
The component RTC from FC7 is a very nice way to use a timer, alarm and RAM (buffered with a battery)
It's support the very accurate time chip DS3231 and the "old" DS1307 with a RAM.
Is it possible soon to include the Chip DS3232 that has both, very accurate time and RAM?
(43.92 KiB) Downloaded 5369 times
I've now added the option to allow you to switch between external and internal clock sources. You were right that it showed the external clock but actually used the internal clock.
If you want to try the latest for me then please follow the steps below.
The attached file needs to be placed into the "Flowcode 7/CAL/PIC32" folder.
PIC32BIT_CAL_RTC.c
(4.84 KiB) Downloaded 321 times
Then these updated definition files must be extracted to the "Flowcode 7/FCD/PIC32" folder before restarting Flowcode.
PIC32.zip
(340.99 KiB) Downloaded 285 times
I'll add the DS3232 to the list, should be fairly simple to add when we next get some free time.
Thank for all the infos.
I tried and it's working to switch to the extern OSCI.
But it's not alway starting the OSCI
The quarz is like on picture Q1 connected
to Pin C13 and C14.
I tried all gain and kickstart of the SOSC but still not stable.
Next week I will trie on an another board with a Pic and a different way to connect the OSCI
(39.95 KiB) Downloaded 5359 times
(63.07 KiB) Downloaded 5359 times
The DS3232 is working with the DS3231 componet except the RAM.
Is it possible to have it soon for FC8?
It helps me to save a few configurations bytes
Thanks for reminding me :wink:
I've pushed a v8 update now with a mod to the RTC component for the DS3232.
Let me know how you get on.
Thank you for the help.
Set and get of time of the DS3232 is working still fine.
Set and get of RAM is not working. It's not freezing but if I set the Ram-addres 1 to value 65, I always read an 0.
Also the number ram of 55 is not like in the data sheet ...
But 55 would be enough....
♦ 236 Bytes of Battery-Backed SRAM
Hi Stefan,
Many thanks for letting me know. I've fixed the tool tips so they now correct show the right address range and also found and also hopefully fixed the bug stopping the RAM from being accessed.
Thank you Ben. It's perfect now.
something to smile
How to set the time if there is no keyboard or comunication or for the prototype.....
If both (string) format are the same then it would be even easier
(88.24 KiB) Downloaded 4481 times
stefan.erni wrote:How to set the time if there is no keyboard or comunication or for the prototype.....
If you're interested, I used to set time and date via PC (from the PC clock time) and UART to USB converter.
I also created an Android mobile app which can set the time and date of RTC to the time on the phone via Bluetooth.
I could help you with that.
Thank you Martin for the help
Unfortunately, I have no uart or bluetooth available on this board. What I have is the ESP8266 wifi module. To creat a wifi and accessing it from an Internet explorer works fine. somehow I will transmit the time this way.
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Post by AbhijitR »
Hello! Martin
I was trying to search something relevant to your post, is it possible in FC8 to use some function so that the actual date and time from the computer will be transferred or programmed while compelling the flow chart, more or less like programming the "Programmable Relay" like ZELIO or LOGO manufactured by Schneider or Siemens.
Thank you.
Abhi
Hello Abhi,
The "Auto Version Identifier" component available from the Storage component category (now Data -> Storage) will do this for you.
Here is the Wiki page on the component.
https://www.matrixtsl.com/wiki/index.ph ... 91fb19f63f
AbhijitR
Post by AbhijitR »
Hello! Ben
Good morning
Many thanks for the reply, I will try that out today and keep you posted.
Abhi
