Re: Internal Real Time Clock RTCC PIC8 & PIC16
Posted: Wed Feb 27, 2019 5:11 pm
Hello! Ben
Following your post I tried to use the Auto Version ID function, it is really a fantastic utility.
But now I am stuck up with another issue, I was not able to convert the string data to integer, I mean I could write the instruction but I lost the data after conversion. I took "Date" from auto version as string i.e. 27-02-2019 then converted the same to integer which eventually ended up in only 27. I tried to read the post but not getting the correct link, may I request you to shed some light.
I check the conversion/result on the LCD screen and on computer simulation.
Thank you, hear you soon.
Abhi
Abhi
