PIC16F18345 EEPROM Compiler problem founded
danilof
Re: PIC16F18345 EEPROM Compiler problem founded
Post by danilof »
For correct analysis use the attached files. Disregard the other files in the analysis. They had setup errors, but the problem remains the same.
TEST PICF18345 T2.fcfx
(7.34 KiB) Downloaded 260 times
TEST PICF18345.fcfx
(7.33 KiB) Downloaded 260 times
Hi Danilo.
Sorry, I have never used PIC16F18345.
So I don't feel confident I can assist.
Perhaps someone else who knows about your microcontroller can help further.
danilof
Post by danilof »
Martin,
Many thanks. Perhaps Benj could give me some help. I have sent a message to him.
Thanks a lot.
First of all can you make sure you are using the latest files.
1) the EEPROM CAL file needs to be placed into the "Flowcode 7/CAL/PIC" folder.
PIC_CAL_EEPROM.c
(4.65 KiB) Downloaded 236 times
2) the device definition file needs to be placed into the "Flowcode 7/FCD/PIC" folder.
16F18345.fcdx
(29.19 KiB) Downloaded 230 times
This should hopefully then work correctly. I've tested the new code on a 16F18877 which is a similar family and this is working really well.
Let us know how you get on.
danilof
Post by danilof »
Dear Benj,
Now it works. Many Thanks!!!
Question: I know that on FC6 the view asm exist, but on FC 7 it isn´t. Is it possible to have on FC7 the .asm? it will be very helpfull for debugging.
Brgds,
Brilliant glad it's working for you, thanks for letting us know.
There is a .as file that's created in the project directory that contains the assembler code.
