Global emergency stop via interrupt
Has thanked: 481 times
Been thanked: 699 times
Re: Global emergency stop via interrupt
Hi Monie,
I've had another look at your program and made a suggested change, no interrupt needed.
Leigh
Miac Interrupt Emergency Stop-004.fcfx
(33.4 KiB) Downloaded 251 times
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hi LeighM
Now the program works very well ;-)
Thank you very much for your great help.
Really good working day
Really good working day :D
Best Regard
Monie
Monie Jacobsen
Hi LeighM
Had to use Q4 - B7 for Reset [/ b] instead of B2 ?????
What's wrong here?
See attached file:
Miac Start Stop Reset1.fcfx
(35.64 KiB) Downloaded 241 times
Wishing to be able to use KeyPad 5 = Noedstop and Keypad 3 = Reset, the place for loose contacts.
Have the same issues as above!
Is it something you would like to help correct so Keypad can be used?
See attached file:
Miac Start Stop Reset with KeyPad.fcfx
(34.63 KiB) Downloaded 253 times
Best Regard
Monie
