Hi Rod.
I have tried your flowchart with EPIO40P which also uses 33EP256MU806 and it's working as expected.
With analogue i/p connected to the + supply, my logic Analyser showed:
What connection have you got the analogue voltage connected to on your BL0032 & can you measure the voltage with DMM?
UART Component - USB-UART FT232RL hardware
Re: UART Component - USB-UART FT232RL hardware
Hi Martin, I dont know If I made myself clear, but what i was trying to explain on my last post is: I cant get the uart comm to read the analog changing while using flowcode.
On the other side, while I use a third party for example mikroe uart, iam able to read the analog changing through Uart.
Thank
Rod
Thank
Rod
- IMG_20220128_151957.jpg (90.28 KiB) Viewed 2439 times
- IMG_20220128_151948.jpg (138.68 KiB) Viewed 2439 times
- Analog_Output_Pot.jpg (88.86 KiB) Viewed 2439 times
