Flowcode V4
Re: Flowcode V4
ITISVARESE wrote:Hello Benj,
all last Your solution (V4 in other directory) don't work....
This is a big problem for Vista users.
I agree. It could a Vista version issue.
On my laptop, which has Vista Home Premium SP1, flowcode V4 is working.
On My main PC I have not upgraded to SP1, and flowcode does not compile to hex - see above screen shot. However flowcode V3 does work.
Also referring to screen shot as you can see, file I was trying to compile is in a directory called converted.
The flowcode program be default goes into program files\matrix Multimedia\Flowcode V4 etc, and not in C:\root.
I will try re-installing V4 in a different directory from program files. Failing that, will upgrade to SP1 and will post findings.
Re: Flowcode V4
I will try installing the "PS Tray Factory" software onto my Vista computer this weekend and see if it has any negative effects,
So far we have tested on a fairly large number of Vista machines using default and non default directories and found no problems at all.
Has anyone tried my suggestions to see if they help to get around the problem, Obviously not a long term solution but at least it might help with tracking the cause of the problem...
You could try moving your program to a directory just off the root to see if this helps the problem
Eg. C:\Progs\
If this doesnt help then another thing you could try is to install Flowcode into a folder off the root directory.
Eg C:\FC3 or c:\FC4
These tests will eliminate the path technicality which will hopefully help to get to the bottom of this problem.
ITISVARESE
Has thanked: 9 times
Been thanked: 3 times
Re: Flowcode V4
Post by ITISVARESE »
Hello Benj,
See up for me don't work.
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Re: Flowcode V4
Post by saschech@gmx.de »
Hallo Benj
In the moment i have install v4 on my son`s del high-end laptop ,it works well
With ps tray factory i show the thame as on my pc..........
I want help,so i install to c:\flowcode V4 but it is the same situation!
File name: D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c
Generated by: Flowcode v4.0.0.53
Date: Friday, June 12, 2009 19:37:46
Licence: Demo
***DEMO VERSION***
NOT FOR COMMERCIAL USE
Launching the compiler...
C:\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "1. Displaying a number.c"
Return code = 0
FINISHED
Regards Wolfgang
Re: Flowcode V4
Not sure if this will help.
Attached are two text files.
One is installation log from a working V4
Other is installation log from a non working V4
Could there be any clues why non working V4 does not compile a hex file by looking at both logs?
Installed V4 on both PCs as follows:
1) Un-installed V4 using add/remove in control panel.
2) Deleted both entries of V4 form registry files (HKEY_LOCAL_MACHINE\SOFTWARE\MatrixMM\FlowCodeV4) and (HKEY_CURRENT_USER\Software\matrixmm\FlowcodeV4)
Ran same install file on both PCs
Entered Pro Key.
Loaded same example file.
Results from non working PC:
File name:     L:\Flowcode_V4_Examples\Examples\Interrupts\1. RB0 interrupts.c
Date:          Sunday, June 14, 2009 03:12:11
Licence:       Professional
Registered to: Martin
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "1. RB0 interrupts.c"
Return code = 0
FINISHED
Results from working PC:
File name:     D:\Flowcode_V4_Examples\Examples\Interrupts\1. RB0 interrupts.c
Date:          Sunday, June 14, 2009 03:18:32
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
1. RB0 interrupts.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" "D:\Flowcode_V4_Examples\Examples\Interrupts\1. RB0 interrupts.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F88 -la -c2 -o "D:\Flowcode_V4_Examples\Examples\Interrupts\1. RB0 interrupts.pp" -v -d _BOOSTC -d _PIC16
1. RB0 interrupts.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "1. RB0 interrupts.obj" -t PIC16F88 -d "D:\Flowcode_V4_Examples\Examples\Interrupts" -p "1. RB0 interrupts"
BoostLink Optimizing Linker Version 6.95
Warning unreferenced functions removed:
	 FCI_FLOAT_TO_STRING	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 FCI_NUMBER_TO_HEX	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 FCI_STRING_TO_INT	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 FCI_STRING_TO_FLOAT	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 Wdt_msDelay	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 Wdt_Delay_S	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 Wdt_Delay_Ms	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
	 isinf	 in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Building CASM file
Memory Usage Report
RAM available:368 bytes, used:36 bytes (9.8%), free:332 bytes (90.2%),
Heap size:332 bytes, Heap max single alloc:110 bytes
ROM available:4096 words, used:95 words (2.4%), free:4001 words (97.6%)
success
Return code = 0
FINISHED
I upgraded PC with non working V4 to Vista home premium SP1 form just Vista home premium. So both PC's have simular operating systems.
PC Spec non working V4:
OS Name	MicrosoftΒ® Windows Vistaβ„Ά Home Premium
Version	6.0.6001 Service Pack 1 Build 6001
Other OS Description 	Not Available
OS Manufacturer	Microsoft Corporation
System Name	MARTIN-PC
System Manufacturer	HP-Pavilion
System Model	GQ504AA-ABU a6220.uk
System Type	X86-based PC
Processor	Intel(R) Core(TM)2 Duo CPU     E4400  @ 2.00GHz, 2000 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date	Phoenix Technologies, LTD 5.21, 27/07/2007
SMBIOS Version	2.4
Windows Directory	C:\Windows
System Directory	C:\Windows\system32
Boot Device	\Device\HarddiskVolume1
Locale	United Kingdom
Hardware Abstraction Layer	Version = "6.0.6001.18000"
User Name	Martin-PC\Martin
Time Zone	GMT Daylight Time
Installed Physical Memory (RAM)	2.00 GB
Total Physical Memory	2.00 GB
Available Physical Memory	829 MB
Total Virtual Memory	4.23 GB
Available Virtual Memory	2.92 GB
Page File Space	2.29 GB
Page File	C:\pagefile.sys
PC Spec working V4
System Manufacturer	TOSHIBA
System Model	Satellite L350
Processor	Intel(R) Pentium(R) Dual  CPU  T3400  @ 2.16GHz, 2166 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date	INSYDE 1.60, 23/12/2008
SMBIOS Version	2.4
Boot Device	\Device\HarddiskVolume2
Total Physical Memory	1.87 GB
Available Physical Memory	859 MB
Total Virtual Memory	3.98 GB
Available Virtual Memory	2.62 GB
Page File Space	2.16 GB
Working Flowcode V4 log from laptop.zip
(209.33 KiB) Downloaded 461 times
Non working Flowcode V4 log from pc.zip
(232.68 KiB) Downloaded 435 times
ITISVARESE
Re: Flowcode V4
Hello Benj,
very strange don't work on Vista SP2 and work on Seven RC1 7100 in VM VMWARE on PC that don't work.
On Seven i receive only this warning (also in PC with XP that work):
Other: it is a case but medelec35 says that V4 don't work on Pavillon HP; also my PC is Pavillon HP with Vista.........
Re: Flowcode V4
Thanks for all the responces here hopefully we are closer to a solution.
Installing to "C:\Flowcode V4\" does not get around the 8.3 filename problem. Try "C:\FC4\"
Also thanks for the log files Medelec.
I have had a look through but I cant spot anything which looks incorrect or like it should cause these problems.
Im still digging trying to replicate this problem. Ill give it another go tonight and hopefully get somewhere with reproducing the problem and hopefully the fix.
Re: Flowcode V4
Your welcome Ben.
If you want to paste a list of things to try on a PC with a non working V4 Fowcode, I'm sure you will get quiet a few volunteers including my self.
Any other information required, e.g registry screen shots etc just ask.
Would you like this thread to continue, or start posting in on V4 Flowcode section?
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hello Benj
The result with running ps tray , install c:\FC4\ :
File name: D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.c
Date: Monday, June 15, 2009 20:55:34
Licence: Demo
***DEMO VERSION***
C:\FC4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "2. Counting using loops.c"
Return code = 0
FINISHED
_____________________________________________________________
stopp ps tray :
Date: Monday, June 15, 2009 20:59:00
Licence: Demo
***DEMO VERSION***
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
Starting preprocessor: C:\FC4\BoostC\pp.exe "D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.c" -i C:\FC4\BoostC\include -d _PIC16F88 -la -c2 -o "D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.pp" -v -d _BOOSTC -d _PIC16
2. Counting using loops.c success
success
Return code = 0
C:\FC4\BoostC\boostlink.pic.exe -ld "C:\FC4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "2. Counting using loops.obj" -t PIC16F88 -d "D:\sachs_work\V4_Examples\Components\7 Segment" -p "2. Counting using loops"
Caution: Delay inaccurrate: 'delay_ms', Delay overhead:0ms, Unit delay:1.00016ms, Delay resolution:1 units
FCI_FLOAT_TO_STRING in: C:\FC4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\FC4\FCD\internals.h
FCI_STRING_TO_INT in: C:\FC4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\FC4\FCD\internals.h
Wdt_msDelay in: C:\FC4\FCD\internals.h
Wdt_Delay_S in: C:\FC4\FCD\internals.h
Wdt_Delay_Ms in: C:\FC4\FCD\internals.h
isinf in: C:\FC4\FCD\internals.h
FCM_INTERRUPT_TMR0 in: D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.c
FCM_INTERRUPT_RB0INT in: D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.c
FCM_INTERRUPT_PORTB in: D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.c
FCD_LED7Seg10_ClearDigit in: D:\sachs_work\V4_Examples\Components\7 Segment\2. Counting using loops.c
Building CASM file
Memory Usage Report
RAM available:368 bytes, used:47 bytes (12.8%), free:321 bytes (87.2%),
Heap size:129 bytes, Heap max single alloc:94 bytes
ROM available:4096 words, used:216 words (5.3%), free:3880 words (94.7%)
success
Return code = 0
FINISHED
_____________________________________________________________________
It is the thame situation......
Regards Wolfgang
Re: Flowcode V4
Hello everyone,
I've been able to replicate this problem, so I should have a solution for you later today. Watch this space!
Re: Flowcode V4
Ok, no solution yet but I do have a description of the problem and a workaround.
The problem occurs on my Vista Ultimate laptop (with SP1). To replicate the problem, run Flowcode, create a new file and save it. Try to compile this and it will not compile. You will get the "Launching the compiler..." message, and after a short while you will receive the "Return code = 0" message.
As a workaround, you can now close Flowcode. Then restart it, and load the file you just saved. This should compile ok, as should any file you open.
BUT... as soon as you create a new file and save it, the problem will occur again. And you will not be able to compile any programs until you close and restart Flowcode. This seems very strange - something occurs when saving a new file that prevents the compilation. I will continue to investigate this today.
This problem did not occur on Vista without SP1. Nor does it occur on XP (SP3).
Can others on this forum please tell me if this is the correct description of your problem.
Re: Flowcode V4
steve wrote:This problem did not occur on Vista without SP1.
The problem of not compiling to hex was occurring on windows vista pre sp1.
As stated in my previous post Up graded to sp1 so both PC’s can be compared like for like.
steve wrote:Can others on this forum please tell me if this is the correct description of your problem.
Yes same issue. I.e
steve wrote:Try to compile this and it will not compile. You will get the "Launching the compiler..." message, and after a short while you will receive the "Return code = 0" message.
Re: Flowcode V4
Does my workaround work for you??
Re: Flowcode V4
I will not have access to the non-working V4, until 6pm tonight.
I will try what you suggest, and post results then.
I did not save any files prior to compiling. I loaded Flowcode with a sample that is in \Flowcode_V4_Examples\Examples\Variables & Operators
Available as a download from Matrix site.
None of those examples complied at all.
ITISVARESE
Re: Flowcode V4
workaround don't work for me (Vista SP2)
ITISVARESE
Re: Flowcode V4
Hello;
I have made other test: installed on same PC V3 and V4 , created a new file on V3
and set compiler option on V3 to Boostc directory of V4: file compiled ok and reverse not work.
Re: Flowcode V4
steve wrote:Does my workaround work for you??
No, work around does not work for me either.
Re: Flowcode V4
Hi everybody,
Please see this thread:
http://www.matrixmultimedia.com/mmforum ... =29&t=6481
I am hopeful that this will help get closer to a solution to this problem!
