that means 800steps for 4rev,and 50 for .5rev.afterthat if ve want more resolution ,i mean .25rev we cannot set our loop variable to 12.5count.
am i correct?
then what should be do the quaters?and other under half valeus.
are we going to create again direct port addressing like 96 to portc,80to port c. - . -. -.
nuwan.
stepper motor cct
- fotios
- Has thanked: 109 times
- Been thanked: 117 times
Re: stepper motor cct
OK, your motor is indeed NEMAxx standard Hybrid of 1.8deg/step (or 200step/rev). That is a good start point. Please, give me some time to experiment with it. I will reply you in 1 hour as much.nuwan5213 wrote:Hi
am i correct?
nuwan.
Fotis
Best Regards FOTIS ANAGNOSTOU
- fotios
No, you are wrong, it goes in this way: 1rev = 200steps so 0.5rev = 100steps.nuwan5213 wrote:Hi
am i correct?
Fotis
nuwan5213
- Has thanked: 24 times
- Been thanked: 4 times
hi again fotis,
please check tis out.
program called "impossible" is not working well with hardwear.wrong positioning again.but 4rev,1rev,and half rev works fine.
awiting reply.
thanks.
nuwan......
awiting reply.
thanks.
nuwan......
- ST_MOT_MOD_quater_possible_edit.fcf
- (10 KiB) Downloaded 245 times
- ST_MOT_MOD_quater_impossible_edit.fcf
- (9 KiB) Downloaded 262 times
- ST_MOT_MOD_half_reviution_edit.fcf
- (9 KiB) Downloaded 248 times
Electronics for better world.
- fotios
OK nuwan
We have the correct data of stepper motor, 1revolution = 200steps. Let's look at the issue from a different optic angle. I don't know the length of elastic that cuts your machine per 1 motor revolution.. From your machine picture i can suppose that is about 30mm (or 3cm). Let's suppose that indeed cuts 30mm of elastic / 1 motor revolution, OR 200 motor steps = 30mm elastic piece. Therefore:
1) For 300mm (or 30cm) elastic piece: 300mm X 200steps / 30mm = 2000steps
2) For 550mm (or 55cm) elastic piece: 550mm X 200steps / 30mm = 3666.66steps. In this case you could change the length from 550mm to 549mm (1mm is negligible for elastic) and you will get:
For 549mm (or 54.9cm) elastic piece: 549mm X 200steps / 30mm = 3660steps.
In your original file "STEPPERMOT_MOD3.fcf" the variable "COUNT" is increased by "1" per each Loop repetition (COUNT = COUNT + 1), or by "4 steps" per each Loop repetition. So you have to divide the number of steps (calculated above) by 4 and to write on "Until COUNT = ---" the result of division, i.e. for 2000steps you have to write "Until COUNT = 500", for 3660steps "Until COUNT = 915" etc.
I don't think that is a right way, a better and more accurate way is to we change the structure of each branch of your program. To this, the calculation "COUNT = COUNT + 1" should be executed 4 times per each Loop repetition, i.e. after each one of the 4 Output icons it should be placed one calculation icon "COUNT = COUNT + 1". In each output icon a 4bit code is writen which corresponds to one of the 4 phases of stepper motor, or to ONE STEP. I have modified just 4 branches of your fcf to you get an idea of what i mean. To make your project working correctly on your actual machine, you have to measure how much is the length of elastic that cuts your machine per 1 revolution of motor, to make the calculation of steps according to the formula that i described above, and to write the number of steps result in the Loop "Until COUNT = ---" of each branch.
Fotis
Fotis
- STEPPERMOT_MOD3.fcf
- (20.82 KiB) Downloaded 289 times
