MOD Operation selected after Minut
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Re: MOD Operation selected after Minut
Post by Monie Jacobsen »
Hi kersing
Rigtigt mange tak.
Never used these terminals before. But is now connected as you refer to;-)
You need to connect to Miac RX and TX, the pins upper right, next to the power connector
Here' I do not really know what you mean here!
"And of course set the component to use that serial port"
Is it RX Remap Pin Port E.1. Or what do you mean? Should "Port E.1" be connected to a serial port. Where is this "serial port"?
Serial port.JPG (72.55 KiB) Viewed 19360 times
Best Regard
Monie
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
The serial port settings you show are correct IF the jumper settings in the Miac are correct. Check the data sheet to see the jumper settings (page 11, one of the first three diagrams is OK)
Check the documentation of your GPS module to see if it uses 9600 bps or 38400 bps for the communication speed.
― C.S. Lewis
Monie Jacobsen
Hi kersing
Thank you very much.
Looking at it tomorrow. OK ;-)
Best Regard
Monie
Monie Jacobsen
Hi kersing
Would like to be careful here not to pills too much in dsPIC Miac!
Can you see which jumper to move And to which??
Best Regard
Monie
kersing
Post by kersing »
Please check the documentation. I mentioned the page and settings in my previous message.
― C.S. Lewis
Monie Jacobsen
Hi kersing
Which jumper settings in the Miac are correct????
Is this this jump settinge to be used below?
Best Regard
Monie
kersing
Post by kersing »
So that one is correct, but the settings in your picture are correct as well.
― C.S. Lewis
Monie Jacobsen
Hi kersing
So burned off GPS :(
Best Regard
Monie
kersing
Post by kersing »
Have you checked the gps documentation for the default communication settings?
If you happen to have a serial to usb converter you can connect the gps to it to check it is working as expected.
― C.S. Lewis
Monie Jacobsen
Hi kersing
Have both before and now where GPS does not work anymore.
And test the GPS device on ardunie uno.
So GPS is OFF ;-)
Best Regard
Monie
