V5 ADC - error during compile
Jay Dee
Has thanked: 121 times
Been thanked: 154 times
Post by Jay Dee »
Hi all,
Using an ECIO 40P and just starting to play with V5 ( nice work by the way, like the new variable types and annotation features )
Tried to compile a previously working FC4 program and got an error message relating to the PIC_CAL_ADC.c
Had a look at the relavent line in the C file but did not give me any hints as to the issue ( I'm awful at C, thats why I use FC! ;-) )
It could be something just confused in my install, I guess?
I wrote a new simple FC V5 program using the ADC component in V5 and got the same result when compiling.
Test_V5_ADC_Comp.c
Starting preprocessor: C:\PROGRA~1\Flowcode\v5\Tools\boostc\pp.exe Test_V5_ADC_Comp.c -i C:\PROGRA~1\Flowcode\v5\Tools\boostc\include -d _PIC18F4455 -la -c2 -o Test_V5_ADC_Comp.pp -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
C:\Program Files\Flowcode\v5\CAL\PIC\PIC_CAL_ADC.c(1588): Illegal symbol name: (
1 errors detected
Error: preprocessing error
failure
Return code = 1
Any pointers appreciated, i keep thumping keys at this end to see if I can get it working. If it compiles smoothly for anyone else, then it must be my system.
Test_V5_ADC_Comp.fcf
(9 KiB) Downloaded 330 times
Re: V5 ADC - error during compile
Hi Jay,
I have had a look and I think I may have found what's causing the problem.
Can you make a copy of PIC_CAL_ADC.c
in C:\Program Files\Flowcode\v5\CAL
or if 64 bit windows C:\Program Files (x86)\Flowcode\v5\CAL
and replace with attached file.
I'm not an expert like Ben so this is unofficial temporary fix as this may or may not affect something else.
I'm sure Ben can then give an official fix on Monday and tell me I have also made a mistake lol.
If this fix does not work, I will take another look at it. I don't give up easily :)
At least you know its not your system
Note: Untested on hardware.
PIC_CAL_ADC.c
(84.85 KiB) Downloaded 363 times
Fix I can now confirm as working on 18F4455 hardware.
Affected devices:
18F2220, 18F2221, 18F2320, 18F2321, 18F24J10, 18F2410, 18F2420, 18F2423, 18F2450,
18F2455, 18F2480, 18F25J10, 18F2510, 18F2515, 18F2520, 18F2523, 18F2525, 18F2550,
18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F4220, 18F4221, 18F4320, 18F4321,
18F44J10, 18F4410, 18F4420, 18F4423, 18F4450, 18F4455, 18F4480, 18F45J10, 18F4510,
18F4515, 18F4520, 18F4523, 18F4525, 18F4550, 18F4580, 18F4585, 18F4610, 18F4620,
18F4680, 18F4682 & 18F4685
Jay Dee
Post by Jay Dee »
Nice one Martin!
Compiled and working on my hardware as well. No reason to stop working/play on the weekend now!
Thanks for quick reply and workaround. J.
Thats great Jay!
That's why I tried to get V5 up and running, Its just too good just to sit there doing nothing :lol:
Need to get use to all the new features :)
Have a good weekend playing.
Just been searching though posts and this is the same issue that Jonny answered here:
http://www.matrixmultimedia.com/mmforum ... 445#p31445
I have removed a bit more than he has suggested.
Wish I could of found that 1st lol.
From what I can see see my modification will have an issue with 12 bit ADC if that exists within the devices I mentioned.
I will go through the device listing and If I do find that to be the case then I will re-post file but as per Jonnys suggestion.
Reason I remove 12bit is because this was not present in type13 ADC for FC4
