max MIACs in a CAN network
thusharag
- Flowcode v5 User
- Has thanked: 9 times
- Been thanked: 3 times
could you let me know the maximum possible number of MIACs can be connected through CAN terminals to acheve a hassele free operation practically. we will guess one MIAC sends five numbers of frames for a second to the CAN network.
Thanks & Regards,
Thushara Goonathilake.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: max MIACs in a CAN network
Hi Thushara,
I suppose it depends on the frequency and size of the messages that you are sending across the CAN network. But even with a lot of communication traffic, I think you should be able to connect 30 or 40 without any problems at all.
thusharag
- Flowcode v5 User
Thanks steve. If i use 5 frames with 8 data in a second from one MIAC, is this condition also ok to use more than 30 MIACs successfully?
Thanks & Regards,
