Flowcode Crash with keymapping
I class this as a non serious crash since it only crashes due to an overlooked mistake on the users part.
If for example you have selected 4 switches from the switch bank and mapped them all to keys 0 to 3.
Then in the properties reduce switches from 4 to 3, if you press the key that corresponded to the removed switch then Flowcode will crash.
This will happen with the attached Flowchart if you press the number 3 during simulation.
Fix is simple, just remove the key mapping for switch that has been removed, so it's not a big deal, but I thought I would post about it anyway.
Martn
Button Control2A.fcf
(24.42 KiB) Downloaded 255 times
Re: Flowcode Crash with keymapping
Thanks Martin - we'll get this one sorted.
