TCP_IP send to Server
bogha
Post by bogha »
i'm using Flowcode V4.0
what i'm doing is simple.
i have developed a flowcode that accepts a user keypad input in a specific folmula A*B# and A*B*C#
i just want to send those bytes to a server that is located in a PC, the Server side has been developed using c# and its listning to PORT D ( d is any number )
the problem is that the flowcode was not being able to transmit the byte to the otherside.
any idea how to itialize and connect the component so it can transmit the bytes to the server correctly
thanks
Create UDP or TCP Socket
set destination info
transmit byte by byte
Re: TCP_IP send to Server
I have moved this to the V4 forum because it is more relevant there.
Can you please provide more details about which stage of the process is failing. And what other tools (e.g. Wireshark) are you using to debug your program?
