I used your suggested method (see Flowcode V4.5 flowchart attachments) and they run fine in simulation and config. and download with no problem. However, when I tried the chips hardwired I get no result at the Rx (lighting the appropriate 1 of 6 LED's on Port B dependent on the contact being made on Port A).
The 'other' details are: I am using 3.3 volts supply (the LF version is 2v to 3.5v), Internal oscillator, INTRC as Port I/O, clock speed 19660800 Hz
After programming I kept it simple for the test of one switch and one LED, the ONLY conections I have made therefore are: +ve, -ve, Tx Pin 11 to Rx Pin 8 (UART signal), a 10k pull-down resistor from RA0 (input) with a clean contact across +ve and RA0 for the Transmitter and on the Receiver - an LED from RB0 (output) to -ve via a 1k resitor.
Any ideas would be greatly appreciated - I have run out of things to try now.
Best regards,
Chris
