Making a thermostaat with the buggy
For Formula Flowcode Micromouse users to discuss projects, flowcharts, and any other issues related to the Formula Flowcode Micromouse.
Dieter
Post by Dieter »
I wondered whether it was possible to make a termostaat with the Formula Flowcode buggy.
Here I would connect a temperature sensor (DS1820), use an LCD display for monitoring the temperature and use a relay to switch a heat component.
Something like this http://www.youtube.com/watch?v=r_D0ORrx ... re=related buth then with the formula flowcode buggy
Re: Making a thermostaat with the buggy
This is technically possible but you may not be able to use the buggy as a robot as you would have to use some of the I/O lines in your application.
