I'm using dsPIC 4.3 to program a 30F6012A. I am using a 4MHz crystal and my clocksetting is X16 PLL mode. That should give me an internal frequency of 64MHz. And that is what I have entered in the projects setting and everything seams to be workin. A 100ms delay is realy 100us when I am checking with a scope. I have a 20x4 LCD display attached and it works fine. I also have internal CAN and UART1 enabled and here is the odd part. Both the CAN and the RS232 seams to be running at half speed. If a set the CAN speed to 250 b/s, my CAN diagnostic tools (I've tried two different models ) are telling me that I am running at 125b/s. Setting half the speed on the CAN diagnostics gives correct readings and communication is without any problem. Setting the CAN tools to 250b/s makes the data unreadable.
The same thing happens with my RS232 using UART1. If i set the speed to 9600, I can read the data beeing sent without any problem if I set the speed on the bus analyser tool or the serial port on a PC to 4800. Does anyone have any ideas about what is going on?
What is my clock speed?
Jump to
- Announcements
- ↳ Announcements
- The Knowledge Exchange
- ↳ Programming Tips & Tricks
- ↳ Freelance Embedded Engineers
- ↳ Article Discussion
- Microcontroller Programming
- ↳ General Programming
- ↳ Flowcode V9
- ↳ Flowcode V8
- ↳ Feature Requests
- ↳ Bug Reports
- ↳ User Components
- ↳ Flowcode V7
- ↳ User Components
- ↳ Feature requests
- ↳ Bug reports
- ↳ Fixed bugs
- ↳ 8-Bit PIC
- ↳ 16-Bit PIC
- ↳ 32-Bit PIC
- ↳ AVR & Arduino
- ↳ 32-Bit ARM
- ↳ Poll Discussion
- ↳ Flowcode V6
- ↳ Flowcode v6 Beta
- ↳ Bug reports
- ↳ Getting Started
- ↳ User Components
- ↳ Bug reports
- ↳ Flowcode V5
- ↳ Flowcode V5 Issues
- ↳ Flowcode V5 Suggestions
- ↳ Flowcode V5 Free Edition
- ↳ Flowcode V4
- ↳ Flowcode 4 Bugs
- ↳ Flowcode 4 Suggestions
- ↳ Flowcode V2 & V3
- ↳ General / Misc
- ↳ Components (Comms)
- ↳ Components (Other)
- ↳ Bugs / Application Errors
- ↳ Suggestions
- ↳ BTEC Unit 6
- ↳ C and ASM Programming
- ↳ E-blocks
- ↳ Formula AllCode
- ↳ Formula Flowcode
- ↳ MIAC
- Language Support Forums
- ↳ Deutsch Support-Forum
- ↳ Forums d'aide en français
- ↳ Foro de soporte español
- Other Matrix products
- ↳ Electronics products
- ↳ Matrix Online Courses
- ↳ Other products
- ↳ CoCo
- Hidden
