Servo C Compiler Error
BChappy
Has thanked: 13 times
Been thanked: 7 times
Post by BChappy »
I am getting compiler errors when I add the "servo macros"
Attached are the "cut down" versions of my program.
I have the latest V5.1 Pro. install.
My old V4 Pro. seems to show similar errors!
[img]
[/img]
Brian
16F690_NO_enable_servo_.fcf
(6.5 KiB) Downloaded 315 times
16F690_with_enable_servo_.fcf
(6.5 KiB) Downloaded 320 times
Is your Project Not Working? - Help and General Advice Click here!
Flowcode v8 forum topic - Click here!
Re: Servo C Compiler Error
The Servo component requires 2 x capture compare PWM peripherals to allow the component code to define the mark and space of the servo signal correctly.
The 16F690 only has one hardware PWM channel available so it currently cannot be used with the servo component.
