bluetooth solution board can not connect to bt headphone
I am trying to connect bluetooth solution board node b with Bluetooth headphone, i used BT_EX3_Node_B.fcf on cd but i just changed two commands to "ATD00116700016A" and AT+BTK="0000" but i have two responses one after power off then power on the board that is ERROR 05 and when i use reset button that is no carrier did any one knows why?
- BT_EX3_Node_B.fcf
- (9.5 KiB) Downloaded 302 times
Re: bluetooth solution board can not connect to bt headphone
From the looks of it that should be all that is required. Have you managed to get any of the other examples from the Bluetooth solution up and running?
Thanks now EX3 working any way now i have this issue when i try to connect node b with bluetooth headset to broadcast voice i used 3.5mm wire to connect mp3 3.5mm jack to node b microphone jack but i cant here voice on bluetooth headset any way i opened new topic about that so u can see it on link: http://www.matrixmultimedia.com/mmforum ... =2&t=10464
i have the same problem again as mentioned in this topic and i using v4 and tried v3&4 example but i still have the problem but the AT+BTI command is work just find and when try to connect with my mobile phone i got the pair pin message (still didn't find blu2i with devises list of my mobile) but this is not true with laptop & bt headset.
