I am afraid that I'm a newly registered member.
Indeed, the next question made me register and join your community.
I'm an electrical engineering student and I received an assignment from my professor.
I should make a 4x4 keypad and print out values on an LCDdisplay depending on the pushed button.
I have to make my own 4x4 keypad *** . The reason why is not of a huge importance.
I thought someone here could help me and explain me how does the existing 4x4keypad work.
I have to connect 1 row per 1pin so I couldn't come up with any idea how to detect which button was pushed exactly.
I am aware that my problem is more connected with logic than flowcode itself.
Thank you.
[Help needed] Flowcode Keypad
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Re: [Help needed] Flowcode Keypad
Hi eldarjah
Have you had a look at the e-block keypad datasheet. It has a full circuit and shows how the switches are wired.
That way you could make one from conventional push switchs and some resistors.
Simply, when a switch is pushed it joins two of the lines three vertical ie down from 1 2 3 and four horizonal through 1 4 7 *
The pic detects which 2 lines are connected
Hope Ive explained it simply, bit early in the morning & just got to work.
If you can use flowcode, a home brew pad should still work ok.
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
http://www.matrixmultimedia.com/resourc ... 4-30-1.pdf
It will give you idea how to make 4*3 keypad which you can modify to 4*4..
All the programming resources also in the following link..
http://www.matrixmultimedia.com/product ... PHPSESSID=
Have a look n start and let us know how are you getting into that..
Enamul
As john said you can have a look first at the following link...eldarjah wrote:I should make a 4x4 keypad and print out values on an LCDdisplay depending on the pushed button.
Enamul
saber
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
Well it is quite easy.
I will try to explain to you how it works.
Take the datasheet from the eblock with the Keypad.
its all about scanning Colum's and Rows. If you apply 5V on R1:A and you press key 1 then you know that whatever is connected to that pin A you just know that Key 1 is pressed.
However you cannot connect R1:A & R1:B & R1:C to 5V, if you do this you cannot tell if you pressed key 1, key 2 or key 3.
So to interface the Keypad to a PIC, AVR, ARM you would need at least for a 4x3 keypad, 7 I/O available.
For a 4x4 keypad you would need to have 8 I/O.
for a 4x3 keypad connect 3 pins to the Rows and 4 pins to the columns.
I hope this helps you out, if not tell me what you don't understand and I will try to explain more in depth.
Regards Jordy
Regards Jordy
