General questions about V5.x and
Errol
Has thanked: 9 times
Post by Errol »
Before I upgrade I have a couple of question.
Where can I find out which LCD displays,Touch controllers and other devices (non PIC) are supported in V5.x?
Is there a down load of V5.x (30 day eval) if so can you supply the URL?
Does V5.x support any of the graphics library from: Microchip, Mikromedia etc. or do you have your own library?
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: General questions about V5.x and
Post by JohnCrow »
Hi Errol
LCD displays that use the HD44780 controller are compatible with flowcode.
The standard e-block is a 2 line 16 character, I made a custom 4 line 20 character one. You just select the display within flowcode
A simple glcd display (eb-057) is avaliable
A LCD with touch is due shortly.(FC5 only)
This is the latest hardware catalogue
http://www.matrixmultimedia.com/resourc ... php?id=583
You can get info on Flowcode 5 here
http://www.matrixmultimedia.com/flowcode.php
Suggest you have a look through these and the rest of Matrix website.
Someone will answer and more questions you have.
FC5 is a fantastic program, well worth upgrading to though you will still need the pro version for the more advanced e-blocks
