EEProm Initialize Help?
Ok I have all the functionality now working well (thanks to Martin) and would like to store a variable into EEProm.
I obviously need to program an initial value either when the part is burned, or at the very first power up and then check to see if it has been changed and use the new value each time the device is restarted.
Does anyone have a simple example routine for this?
Thanks, Howard
Thanks, Howard
Re: EEProm Initialize Help?
Hi Howard,
What I do is use one additional address to store a key value e.g 22 when I write to EEPROM
Then if the chip is reset and I want to read my stored data from EEPROM:
I first read the key value, if its 22 then I read from the EEPROM location that contains my stored data.
If value = 22:
Yes then read EEPROM
no: //Don't bother reading since EEPROM has not been wrote to yet.
Hope this helps.
I have explained about a similar thing here:
http://www.flowcode.co.uk/mmforums/viewt ... 950#p28950
If your still stuck I can assist you further.
If value = 22:
Hope this helps.
Hi Martin,
Thank you again for the help. I now have it working!
I have noticed a 3 second delay after write in most of the examples. Is this correct for a 16F88??
Warm regards, Howard
Glad I could help.
I write to EEPROM with a project I completed, and I have not noticed any delay with the hardware.
I was writing to locations.
Is the delay with simulator or with your hardware?Collimare wrote: I have noticed a 3 second delay after write in most of the examples. Is this correct for a 16F88??
- AbhijitR
- Has thanked: 284 times
- Been thanked: 80 times
Hello! Martinmedelec35 wrote:Hi Howard,
If value = 22:
Hope this helps.
Kindly excuse but honestly I did not understand the above explanation, my doubt is if I want to store 0 (zero) OR 28, as the initial value of the EEPROM, while loading the *.hex file in the hardware, do I only write 28 in the "Initial Values" in the properties window of the EEPROM and I will be able to read the same value (ie 28) later while running the program in the actual hardware, or there is some other method to do so.
I tried doing the above but I notice the value (ie 28) change to 255 after loading the *.hex file to the chip.
Can you shed some light on this.
Thank you.
Abhi
When sending hex to chip the programmer default setting is to erase all EEPROM values = 255
So if not wrote to EEPROM after programming chip then the value will be 255, that is expected.
Your program needs to write to EEPROM if the value read is 255.
After then when power is removed/restored then EEPROM will contain expected value.
- AbhijitR
Oh! Martin, you make it so simple to understand, but then the option to write the "Initial Value" in the EEPROM properties window is of no use, is it? And in the actual execution of the program in the hardware I can use the value till 254, did I got right.
Abhi
Abhi
In main, before the main loop just read the value of EEPROM.
If value = 255 then write new default value to EEPROM.
Then when power is restored next time the value won't be 255 so the new default value will not be written to EEPROM.
It's been a long while since I looked at Flowcode 5 and I could be overlooking some problem but the initial values field should set the EEPROM values after programming.
Here is the programming sequence.
Delete EE Contents - all values set to 255
Program initial values - anything with an initial value is pre-programmed
Reset into First run - initial values should be available
I thought that was introduced with Flowcode V6? ?Benj wrote:but the initial values field should set the EEPROM values after programming.
@Abhi
As you have posted in the v7 section previously Are you stuck with that version?
- AbhijitR
Hello! Martinmedelec35 wrote: @Abhi
Kindly excuse me if I posted in the wrong section, it is really confusing for me, I thought I posted in the continuation of previous posts in version 5,
Abhi
