Unable to use GSM and GPS Modules simultaneously
awaisnaz
Post by awaisnaz »
I am using the following chips:
PIC18f2550
GSM Module SIM900D at 9600 baudrate
GPS Module M-89 at 4800 baudrate
Problem is that, I can not combine both functions at the same time in flowcode software. If I use GSM module in my flowcode then I lose functionality of GPS ie the GPS flowcode module never responds, and vice versa. (I have used 2-1 mux to control their either gps/gsm input into single RS232 RX, and that hardware is working ok)
During compiling I got errors of tst variable used twice, but I renamed it in gsm component c file, and no more compiler errors. I have attached the flowcode file.
Any recommendations on how to use both of these functions (gps and gsm) at the same time. I can change the pic microcontroller chip if someone recommends that he had successfully used both these functions in some pic microcontroller.
temp.fcf
flowcode file
(27.88 KiB) Downloaded 338 times
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Unable to use GSM and GPS Modules simultaneously
Post by DavidA »
Since you posted a Flowcode v4 file im going to move your post into the Flowcode v4 section.
If you require access to the v4 forums then please follow the instructions here: http://www.matrixmultimedia.com/support ... f=29&t=602
