FloatToString$ issue
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
Hi all,
I have a problem with the FloatToString$ function.
It seems to work OK until the argument to FloatToString$ is larger than 32k.
Above a value of 32k, incorrect values are printed.
Is there a limit to the FloatToString$ function preventing it to convert values above 32k?
jan
Re: FloatToString$ issue
Hi Jan,
Which version of Flowcode are you using?
V4 and V5 use a 16-bit signed variable for the whole portion of the number which only allows 0 to 32657
In v4 you can edit this by opening the internals.h file in the FCD folder and editing this line in the FCI_FLOAT_TO_STRING function code.
	int whole;
to this to get 0 - 65535
	unsigned int whole;
or you could use the following in v5 to get an even larger range.
	long whole;
In v5 the file to edit is the PIC_CAL_STRING.c file in the "CAL/PIC" folder.
