bt solution board connected 2 bt headset but cant hear voice
alsadk
Flowcode V4 User
Has thanked: 3 times
Post by alsadk »
I am trying to broadcast voice to Bluetooth headset from node b Bluetooth solution i used BT_EX8_Node_B-fc4.fcf and i just changed mac address and pairkey to my Bluetooth head set address and pair key so its script 2 changed to:
AT+BTK="0000"
AT+BTW00116700016a
script 3 changed to:
ATD00116700016a
and i connect microphone jack of node b board to mp3 via 3.5mm to 3.5mm wire and the Bluetooth headset seems to be paired with node b board Bluetooth
i tested the wire, mp3 and Bluetooth headset and they work just fine any way t the headset seems like it have just 2 profiles one for telephony and the other is headset and it work any way on computer i found this out by connect the headset to a laptop any way u can see properties of headset (services tab) on the screen shot, but as i said i cant hear voice on Bluetooth headset so is there any command i should send to headset so it can know i am want to use it as headset or something
you can find the EX8_Node_B-fc4.fcf attached.
Update
: the LCD dose not cleared as does in simulation i still do not know why but it seems does not enter audio loop.
(12 KiB) Downloaded 330 times
alsadk
Flowcode V4 User
Re: bt solution board connected 2 bt headset but cant hear v
Post by alsadk »
Update: the LCD dose not cleared as does in simulation i still do not know why but it seems does not enter audio loop.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Hi, since this relates more to a Flowcode program I will move this topic to the Flowcode v4 forums,
If you need access to these forums there is an FAQ topic explaining the quick process here: http://www.matrixmultimedia.com/support ... f=29&t=602
alsadk
Flowcode V4 User
Post by alsadk »
Update: i figured out that connecting with Bluetooth headset failed (this is my assumption) but i do not why can you help me with this please.
